Results 1 to 6 of 6
Thread: 06 RT awd issue
    345hemi's Avatar
    345hemi is offline most service trips on an LX
    Dec 2004
    Lower Mainland, BC
    Unhappy 06 RT awd issue
    I have had my RT just over a year ( bought may 2005) and have quite a list - either i am too picky or ???
    i have about 23000km( 14000miles) and here is a list i took int the dealer ( they seem to fix within a reasonable time frame but still frustrating)
    Transfer Case binding: the transfer case binds first thing in the morning - 5 mile of driving and all is okay. all was okay until after towing my travel trailer up through the mountains( weights about 3000lb loaded). dealer is replacing planetary and fuild as per TSB
    warped rotors: now that car is over 1 year dealer will not warrent
    Uconnect: talk button has black paint rubbed off - white picture of phone is still there - result is red light at night is very distracting
    sunroof rattle: 2 dealers have told me that this is the plastic baffle on left side - if i hold my hand on trailing edge rattle stops - has anyone else seen this?
    Tires: self sealing contis - need I say more?
    Right pull: at what point did they fix this - this is a very early 06 - early may 05 to be exact.
    Trailer wiring: Dealer screwed up on wiring - reverse lights not working.
    earlier on in cars life - engine end seal leaking....oil pan leaked ( AWD shafts go THROUGH the pan)
    am i being unreasonable? Goods thing i bought the extended warrenty that at least gives me rental car.
    06 Blue RT AWD Magnaflow cat back, Veloche Velvet 565 20" wheels and 245/45 20 Continental ExtremeContact™ DWS tires
    Kamakazie2's Avatar
    Kamakazie2 is offline A CarPc in every dash!
    Mar 2006
    Monmouth County NJ
    [quote=345hemi]
    I have the same thing.. my driver side sunroof rattles like crazy.. my dealer is currently looking into it. I know there is a tsb regarding the sunroof but it required the removal of the entire headliner.. im not to happy about that.
    You paid good money for your car, if you are not satisfied with the way the parts are wearing i would demand that it be replaced. Ride them until that warranty expires!
    -Jack
    Brilliant Black Pearl 2006 300C 5.7 AWD
    Real Mods: Predator, AirHammer v2 filter, JBA Headers, HHP/JBA AWD Cats, Corsa Exhaust, Cooper Zeon XST-A 255/55/18, R1 Drilled/Slotted Rotors, BCR Coilovers 15F/15R
    Other Mods:9011 HIR High/Fog:LED Tinted Taillight Assys:Window Visors:SRT-8 Spoiler:Hardwire V1 Install:Footwell Neons:WoodDash Kit:CarPc
    Next: Police rear rotor upgrade 13.8"
    Token's Avatar
    Token is offline First AWD LX in the 12's N/A
    Center of the LX Universe
    Quote Originally Posted by 345hemi
    This one is news to me the RWD's had an issue with the right pull but not the AWD's. I have an 05 AWD, Feb 08, 2005 build date and it's straight as an arrow.
    12.645@108.18
    345hemi's Avatar
    Dec 2004
    Lower Mainland, BC
    AWD + tow = police package?
    I had an interesting talk with the service tech today. I asked him why the service manual says fuse 6 is ( something like) front body computer) and on my car it is the fuse for the center console power outlets. He said that an AWD with Tow is unique in that is is a Police package and that fuse 6 " is meant for police relays" and a few other changes can be done to the flash the computer with the police package. Does this change the specs?
    can any one confirm or deny this? FNKY?
    thanks!
    fnkychkn's Avatar
    greasy cardboard box
    AFAIK, fuse 6 (15 amp) is a B+ feed to the FCM (front control module). fuse 9 (20 amp) feeds the console mounted power outlet. are you sure you weren't reading it upside down?
    AFAIK, police spec. is not available in AWD.
    Token's Avatar
    Quote Originally Posted by fnkychkn
    Spot on as usual fnky. Tried to get some police spec Magnums for our Customs dog handlers. Can get the police pkg, in the 3.5, but not with AWD, simply not offered. Went with the AWD anyways because I figured the only part of the police pkg that was really needed were the upgraded brakes, and the 3.5 AWD's have the good ones aready. We rip out the back seats, and cargo area and put in the dog cage anyway. There is no heavy electrical load because these cars are not marked, and no light bars. No need for push bar either.
    12.645@108.18
