Rear Hatch Won't open
Hello,
I have a 2006 R/T that has a rear hatch that stopped working last week. I can open it sometimes after repeated tries.
Has anyone else experienced this and does anyone have a suggestion of fix for it?
Thanks
Craig
Bump because I just don't know sorry brother.
Coors Light Silver 2005 Magnum RT
MODs MyGig-Nav, 22Elite console cover, Leather door pulls, 10" Alpine Type E Sub in a ME Design enclosure w/ Alphasonik Amp, 3M Invisi-bra, Mopar CAI, 09 replica Challenger Wheels, Mopar Lowering Springs/Eibach Shock Hotchkis Sway suspension.
There was similar post for this same problem...need to keep searching this topic.
I recall that the solution involved climbing into the back of the Magnum and I believe there is a plastic cover on the on the inside of the hatch that you can remove and gain access to the assembly that latches the hatch down.
Good luck
Thanks for the reply,
I spent most of the afternoon working on it. I have the back panel remove and have been al over the locking mechanism. I think either the outside handle isn't working or the solenoid that pushes the locking arm isn't working.
I searched for a similar problem and all I found was information of adding the unlock button to the dash.
I'll keep searching.
Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
