Has anyone else had a problem with the radio changing stations by itself. I have made sure that I did not change via the steering wheel controls. Just started happening. Happens on AM/FM, any station. Any idea before I try the dealership - thanks
I got a newbie!
Welcome from Nova Scotia!
Is your car named Christine?
First, now I dont recall anyone ever posting about this problem so it could be an isolated issue with your unit. Others should chim in shortly. Sounds more like a scan button stuck or something of that nature. Have you spilled anthing on the controls?
WWW.DodgeMagnumGrille.com
Make sure you haven't got the censorship set too high in the EVIC, so the radio doesn't acknowledge questionable content, that it thinks you shouldn't be listening to, and switches the station.
12.645@108.18
I think this is a "special" option on some of the 06 models...the Gremlin option?
Take care,
Christopher
________![]()
________
"I complained to God that I had no shoes, until I met a man with no legs"
An over 40 victim of fate.
'8R'05 Magnum RT Midnight Blue Pearl
KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
Hi Flo Cats
Welcome from Minnesota! Could even be a problem with the steering wheel buttons. Had trouble with mine at about two weeks after puchase. Dealer said it was a module for the EVIC. Started off something simple like you are describing then in a short period (couple trips to work) more things quit (turn signals wouldn't work, couldn't change display). Take it in.
2005 Mineral Gray Magnum RT Yaah, She's Stock!!
180 t-stat, Super Chips F.P., JBA Shorties & High-flow Cats, BillyBoat Performance Exhaust, K&N Filter Charger.
Mine doesn't change stations, but every now and then when I start it up it will end up on satellite no matter where I left it when I turned it off.
When this happens the volume won't turn up (only down) and the station won't change. Turning it off and on doesn't fix it.
The fix is in changing the input mode (am/fm, cd, sat) and then it's back to operating normal and I can then turn the volume back up and change stations.
I wonder if it's the same kinda glitch but affecting mine differently?
'05 GunMetal Gray RT
- 20" Mossa Velize Wheels with Toyo Proxes ST 255/45/20 Rubber
- 2006 Hemi Badges and old Hemi Badges moved to rear window frame andNew Style R/T badge on tailgate
- MDS Indicator
- Factor One Garage's Gunmetal LED Tails
to the Forum.....
Check Us Out Online & Contact Us @ 1-888-894-1115
HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryOČ Paramount NAG1
Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
12.645@108.18
