Results 1 to 10 of 10
    Poco Askew's Avatar
    Poco Askew is offline I'm releasing the flying monkeys!
    Feb 2006
    Southern Oregon
    Question New R/T AWD; wider and lower??
    I picked up an '06 Magnum R/T AWD yesterday.
    I like the R/T RWD wheels a lot, but don't care for the AWD rims. I've been looking over the posts trying to see what my options are. Has anyone actually put 20"x10" rims on an AWD? My understanding is that the only difference between RWD and AWD wheels is the offset (about 25mm vs. 45mm). Also, as the wheel gets wider, the offset should change to fir properly. So on a wider rim, the offset probably should no longer be 45mm. Any wheel geometry gurus out there?
    Also, has anyone found a reasonable way to lower an AWD? I'd love to drop it about 1-1/2".
    Thanks in advance for any suggestions and advice.
    Rick
    Darthvader is offline 'waste of skin'
    Nov 2005
    Rick , The best way I have found to lower an AWD is with Coil over shocks. They are however expensive but offer superior performance and adjustability. There are a couple of coil spring mfg out there but the ride and eveness is not that great and you will end up making other suspension mods to make it sit right,ride decent and handle well. On your control panel you can sort on the subject and find a lot of info on this fantastic forum.
    GoofyTimL's Avatar
    GoofyTimL is offline 300C H.E. and MSRT8 in WV... IS Heaven!
    Oct 2005
    Near Parkersburg, WV
    Welcome to the LXforums Viperguy from our 300C in WV. Good luck with your search for a lower stance.
    Still in love with my first wife, and first car ('68 Charger)... Still have the wife!
    Member #4079.
    Chmie's Avatar
    Chmie is offline Eat My Dust
    Oct 2005
    Lethbridge, Alberta
    Welcome aboard.
    sugar-tj's Avatar
    sugar-tj is offline LX Guru
    Oct 2005
    woodbury nj
    welcome from nj, we need pictures....
    THE ORIGINAL
    http://photobucket.com/albums/c15/sugar-tj/
    there are no strangers here, just friends you haven't met yet..
    NC-SXT's Avatar
    NC Coast
    Welcome to the forum. This thread might help a little
    For those with AWD looking for wheels
    WWW.DodgeMagnumGrille.com
    MrHemi2U's Avatar
    MrHemi2U is offline LX Guru
    Jan 2006
    Pleasant Valley N.Y.
    Welcome from one AWD guy to another
    Before and After
    Ozzie's Avatar
    Ozzie is offline LX Goo'Roo
    SoCal
    Welcome to the forums viperguy. Good to have you here.
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    Welcome. Did you order the RT AWD from the factory or did you buy it off the lot or through dealer locate? I ordered mine from the factory and in that limbo wait state for a while before they build it.
    COLORADOMAGNUM's Avatar
    COLORADOMAGNUM is offline I'm not speeding......I'm qualifying
    Lakewood, CO
    Welcome from another AWD owner. Wheel selection is limited, no doubt. Haven't seen too many lowered AWD's either. There is a spring kit available, but I haven't heard any feedback about it.
    2005 Magnum SXT AWD - Inferno Red
    Mods: Diablo Predator, JBA headers, Zoomers single exhaust, K & N Aircharger, KW coilovers (variant 2's), 402 Motoring tinted tails, lots of Billet Technology stuff, real walnut dash kit, MOPAR on-dash nav, NC-SXT original honeycomb grille, Jina's Embroidery custom headrests.
