Results 1 to 15 of 15
    Haulin426 is offline WAR EAGLE!
    May 2009
    Alabama
    Hello forum! Need info.
    Hello forum. I went to the Mopars at the Battleship show in Mobile and met some guys who told me I should check out the forum. I'm going to a 1/4 mile track Friday night to run this car for the first time. Does anybody have any suggestions for me? Thanks in advance.
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Shut off the ESP, raise the pressure in the front tires to 45psi, lower the rears to about 25psi, keep the coolant temp as low as possible....160-180deg will work wonders. Install a 180 t-stat if you haven't already.I find the best results from only a slight stall against the stock converter of about 1200 rpms and feather the launch (ie don't mash it, but progressively let off the brake as you lay into the gas). A Predator will help tremendously if you have one.
    John Y
    NC-SXT's Avatar
    NC Coast
    Welcome from North Carolina(via Birmingham). There is a wealth of knowlege here so someone will help you out soon.
    WWW.DodgeMagnumGrille.com
    ChargerChick's Avatar
    ChargerChick is offline I'm just Plum Crazy!!
    Mar 2006
    Phoenix, AZ
    Welcome to the forums from Phoenix, AZ!
    MOL SRT-8's Avatar
    MOL SRT-8 is offline SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    welcome from san diego, ca.
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    chris_stx's Avatar
    chris_stx is offline tx magnum
    Mar 2008
    Oak Cliff,Tx
    Welcome from Dallas(DFWLX),TX
    bandaid is offline The "Black Pearl" is going to SF7
    Edmonton
    welcome from Edmonton Alberta
    newchargese's Avatar
    newchargese is offline BALTIMORE MOPAR MOTOR CLUB
    Jul 2008
    BALTIMORE,MD
    Welcome from Baltimore,MD
    B.M.M.C. "Chill Charger"
    Steve HR Hooligan's Avatar
    Steve HR Hooligan is offline All out of money for upgrades
    Mar 2009
    Whitby, Ontario
    Welcome, i hope you have a great run on the track, it'll be a blast
    Steve Hot Rod Hooligan
    Hemi registration # 1132
    May 2009
    Alabama
    Thanks for all the welcomes. I'll let ya'll know tommorow what it runs.
    May 2009
    Alabama
    Leaving at idle it ran 2.1-60ft, 8.9-1/8 at 82.5mph, 13.76-1/4 at 103mph. If I tryed leaving hard it just spun the tires really bad. This was last night, the temp. was 73 and very humid as always in AL.
    KRUZER's Avatar
    KRUZER is offline LX Owners of Waterloo Region Member
    Sep 2008
    Cambridge Ont Canada
    WELCOME to the forum, BUCKLE UP, FLOOR IT,and "HANG ON"!!
    BAD BOYS BAD BOYS ,WHAT YOU GONNA DO...
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Quote Originally Posted by 09CHALLENGERRTTP View Post
    That's a low 13 second car with that trap speed, bud! Get your launch down and you'll be dropping ET's. What were the track conditions and weather like? Did you run on a hot motor or did you get a chance to cool her down....and did you change the tire pressures?
    John Y
    May 2009
    Alabama
    Track conditions were horrible. I didn't really get a chance to let it cool down enough. I still gotta get me a 180 stat. Can somebody tell me about some lightweight wheels that I could put some sticky tires on. I really don't think it's gonna hook up otherwise.
    Chargergurl's Avatar
    Chargergurl is offline Happiness is being first at the light
    Apr 2009
    Calgary
    Welcome from Calgary and good luck with the race!
    2006 Dodge Charger R/T, Brilliant Black, 20" Martin Bros. Death Star wheels, K&N air intake, Borla cat-back exhaust, Diablo 91 Oct CAI tune
    "With great power comes great responsibility." - Spiderman
    http://www.cardomain.com/ride/2246285
