X E Ryder’s Chilly Air Intake (Mod)
As some of you know I am setting my car up for road course, and while working on the front end, I saw an area for improvement. Here is an easy to do mod that you can do in an hour with simple tools, drill, bits, some screws and drive up ramps.
This mod will help direct pressurized air right into your intake. If you have a CAI, and especially if you have the GS Motorsports CAI, this mod should make a difference for you. (The endorsement to the Carbon by Design cover has been removed due to problems with the design of this piece, and customer service at CBD).
When looking at the front end of my car, I noted these two pieces of plastic on either side of the bottom of the radiator, that were flopping around rather loosely. There are designed to keep pressurized air going through the radiator, and not escaping around the sides. The problem is they only have two loose plastic pushpin fasteners to hold them, and they do not seal well at all! We are going to move these two pieces. Use the picture at the bottom for reference.
Drive your LX up on ramps, and pull the service cover under the engine, and the lower cover from the bumper, this will allow you access to see up into the front end below the radiator. Use a screwdriver to gently pull the center pins from the two plastic sidepieces. Note they have a giant “LH and RH” on them for left hand /right hand side respectively.
If you will look up now on the left side, you will see the bottom of your air filter if you have a CAI. By removing that sidepiece, air that enters your bumper will be able to travel directly to your CAI under pressure. In order to maintain pressure in here, we need to seal off the extended chamber we have created.
Take the Left sidepiece and hold its mounting holes up to the frame rail lower spot welded flange, it fits in quite well, but you will have to bend it slightly. Use a felt marker to mark through the holes in the sidepiece onto the frame flange. Obtain a couple screws and perhaps small washers, if you have some OEM type sheet metal bolts with integrated washers, they are perfect. Pilot drill the frame flange where you marked for the screws.
Press the piece against the frame and install the screws. See the picture below for reference. The right side of the car is easier to do, just pull the lower washer reservoir bolt and slip the plastic sidepiece in between the frame and reservoir.
Now that you are done, air under pressure will press into the CAI opening, as well as the leading edge of the radiator, not just the radiator. The sidepieces we relocated help seal off the compartment, but behind the CAI opening now, instead of poorly sealing in front of it. My measured intake air temp dropped between 5 and 10 degrees from this mod, which I logged with my Predator.
1Likes
