Results 1 to 15 of 19
    Neo1130's Avatar
    Neo1130 is offline i poop'd
    Aug 2007
    Olympia, WA
    Where do I get a darn thermostat?!
    Had Adavance Auto Parts look it up, they didn't have one. Matter of fact, they couldn't get ANY that would fit our cars...
    Autozone has the 4127 number as a Duralast unit... Not MotoRad...
    Also couldn't get the Robert Shaw...
    What part number is the Napa for the 4127?
    WIMP's Avatar
    WIMP is offline Attitude, what's an attitude?
    Apr 2006
    Minnesota.
    I've been ruuning a NAPA #165. It's a 180, will throw a code if it's cold enough (once the outside temp is above 30 it's fine) though, opens at 179.
    2005 Mineral Gray Magnum RT Yaah, She's Stock!!
    180 t-stat, Super Chips F.P., JBA Shorties & High-flow Cats, BillyBoat Performance Exhaust, K&N Filter Charger.
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    we can send you one..
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
    the napa number is 191 for their 180* thermostat. i am using a Milodon high flow 180 for a Mopar. it is the same size for the last 45 years.
    Neo1130's Avatar
    Aug 2007
    Olympia, WA
    So the Napa 191 is the same as the Motorad 4127? Well, not the SAME but the same flow and temp?
    isn't the motorad 4127 a 170* thermostat? it is also a high flow? the napa 191 is the bottom of the line as far as thermostats go. i used the napa 191 for over a year before i switched to a Milodon high flow piece.
    Neo1130's Avatar
    Aug 2007
    Olympia, WA
    Sorry my bad, the thermostat from Autozone shows up as Valuecraft!!
    http://www.autozone.com/selectedZip,.../selectZip.htm
    Would this part also work? Says low temp 170?!
    old96er is offline LX Newbie
    Jan 2008
    Quote Originally Posted by 65standard View Post
    Where did you get this, do you have a part number for the Milodon?
    Ella C SRT's Avatar
    Ella C SRT is offline LX Padiwan
    AZ
    Quote Originally Posted by Neo1130 View Post
    The ones from Autozone go by different names with the part numbers 4127 (the 170*) and 4128 (the 180*). As far as I understand, they're all the same.
    The 170* t-stats generally run at 176*... I've been running one from Autozone for months and haven't had a problem.
    Edit:
    Great t-stat info from Meister here:
    http://www.300cforums.com/forums/140064-post1.html
    dwhip's Avatar
    dwhip is online now DMV SLEEPER
    Jan 2008
    VA, but born in that 202 SW
    i just got the 4128 valuecraft tstat from autzone. It says valuecraft on the box, but it should say motorad on the tstat. The 4127 is the robertshaw, they sell it at autozone, but they will probably have to special order it. If can order the 4128 off the autozone website, instead of putting in you cars info when your looking for a part, type in the part number which are 4128 and 4127. I suggest you get the 4128, you run more of a risk of getting codes with the 4127
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    4127 is a valuecraft as well.
    BFNY PERFORMANCE
    RIP My Friend
    OITZBAD's Avatar
    OITZBAD is offline SRT-8
    Florence, MS
    The 4127 or 4128 Robert Shaw both come in value craft boxes. The 180 is good and I hardly threw a code, but now I use the 170 and always have the light on, and have to use my ds programmer to clear the code, but it always comes back. And usually you'll have to order it, only took about two days. But I would only recommend the Robert Shaw, from what I hear its the only thermostat that has a fail safe.
    OITZBAD
    Dantra's Avatar
    Dantra is offline I shaved both of our asses
    Dec 2007
    Indiana
    Milodon 16406 - Milodon High-Flow Thermostat/180 degrees
    JimIsland-SRT8's Avatar
    JimIsland-SRT8 is offline make that a 440 please!!
    Aug 2007
    JAMES ISLAND S.C.
    Neo, do a search here. Meister did a very nice write up. If I recall,you have to tell the Auto Zone attendant to go to the special order section in the computer and type in 4128.I did this and they found it,ordered it, and I had it in several days. No codes and a easy install.
    Neo1130's Avatar
    Aug 2007
    Olympia, WA
    I did do that... They told me they wouldn't give it to me because I would get 10 mpg, run with a CEL and my performance would suffer... That was two different Autozones... I hate Oklahoma for this sort of crap... They only have trucks with Flowmasters in this state...
