What should I do?
I finished my Innovate Wideband install the other day and did a couple of test runs today. The readings looked pretty good @ partial throttle and @ WOT my AFR fluctiated around 7.3 - 7.6. At the end of the WOT run, it it steadily blinked 7.4.
For those who have the Innovate or have any tips on this can you answer my questions?
Does your gauge, I have the DB Gauge, hold a final reading @ the end of your run?
If I log these runs onto the laptop, will I get the same readings? I will be able to datalog once I buy a serial/USB adapter for my sisters laptop.
If everything is accurate/correct should I start to lean out my car with my Diablo?
I am a lil excited cause I dynoed pretty good numbers and ran decent @ the track with this B&G email tune so hopefully leaning it out or maybe getting an email tune from ProMotion Tuning will really unlesh da beast.
CURRENT MODS: AFE II Intake-PWR Heads and Cam-SLP Long Tubes-SLP UD Pulley-Borla 125s-Eagle Intake-NGK V Power Plugs-Moder Muscle Throttle Body-Mopower Chin Spoiler -BT Oil Catch Can-Innovate Wideband-Eibach Dampers-Hotchkis Sway Bars and Lowering Springs-SRT 8 Gears, Mopar TCM-Edge Racing Converter-TransZformer Shift Kit-Lows/Fogs HIDs
