Results 1 to 7 of 7
    STEFF is offline LX Padiwan
    Mar 2010
    VVT Timing Gears / Chain Install Info Needed
    Does anyone have the install info for the phaser and lower sprocket alignment marks positions?
    Rammered is offline LX Padiwan
    Jan 2012
    Bellevue, Ne
    There are rectangles on the chain 2 for the cam gear mark and 1 for the crank gear mark. The crank geaR mark is a dot on one tooth, the cam gear mark is a rectangle and it is on the of the face of the gear and is a little hard to see but it's there.
    Performance Mods:The First Forged 6.6 Hemi In an 09 Ram,Arrington BV Heads,Spartan Eagle Cam,6.1 Intake Manifold,ARH's,BBK 90mm,Edge 3000TC,Hemifever TuningExterior Mods:Factory Bed Liner,Retrax,R/T Grille,Debadged,Blacked Out Exhaust Tips/Ram Heads/Stock 20's on Nitto 305 55 Trailgrapplers,Black KMC Slide 24's on 305 35 Delinte Desert Storms,6000k HI/LO/FOG,Smoked Recon Projector Headlights/Third Brake Light/Tail Lights,Interior Mods: BT Custom Hemi Shifter,Recon Interior LED Kit, Cobra XRS 979
    wo23dodge is offline Big Daddy B
    Apr 2009
    Omaha Nebraska
    Back when I needed this info nobody really helped,then I found this.
    #1 piston at TDC
    timing mark on cam get at 12,then just put the chain on like this and your good to go.
    Wish I could help with the phaser.
    Omaha Nebraska and surroundings mopar group
    2005 Inferno Red Magnum R/T
    Danko shaker hood,Danko grill,Danko chin spoiler.
    2009 SRT8 Challenger wheels,factory 9" front rears widened to 10 1/2"
    My gig
    Getrag 3.91
    2010 Furious Fuchsia Challenger R/T Classic
    6-speed
    gas charged hood struts
    skip shift bypass
    tinted windows
    Sequential tail lights
    LED map lights (green)
    Eibach pro lowering kit with sway bars
    lockpick
    SRT8 exhaust manifolds and cats
    Corsa Extreme catback
    Hurst Comp shifter with pistol grip handle
    Mar 2010
    12 and 6, just like the older Gen 3's. Thanx Guys!!!
    Jan 2012
    Bellevue, Ne
    Quote Originally Posted by STEFF View Post
    Yep only difference is the chain its upside down compared to gen 3's and the cam gear mark... And make sure #1 cyl is ATDC cuz the crank tooth's not exactly at 6 it more like 5:45...
    Jan 2012
    Bellevue, Ne
    How did the install go? Any update got vids or pics?
    Mar 2010
    Quote Originally Posted by Rammered View Post
    No install.....................yet. Just mock up of how it all goes together.
