Results 1 to 12 of 12
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Volant cat back review
    OK, so I got my Volant cat back system delivered yesterday so I decided to run down to the exhaust shop to get it installed. It seemed to go together pretty good, but they were having some trouble getting both tips to line up with the exhaust cut outs in the rear bumper. In fact, after I got home, it seems the passenger side shifted a bit as it's not as centered as it was when I left (I'm so picky, I'll probably try to tweak it over some once it cools down).
    Also, they needed to remove the little cross member and add a few washers as the exhaust pipe was so close it surely would have been bumping up against it with every bump in the road. The finish on the system is pretty good, almost show quality and for $549 shipped to my door I certainly can't complain about it at all.
    Performance wise, I noticed no difference between it and the brylcreem mod I was running, but the sound is WAY better. It was too loud and had a weird sort of tone to it when you'd nail it, where as the Volant system is much more quiet when idling or cruising, but has just the right amount of sound when you lay into it with a nice deeper tone. One other thing I noticed with the brylcreem mod was that it was real obvious when the MDS would kick in (that sucked), so far I can't really tell with the Volant setup. I haven't had it on the freeway yet, but I've noticed no drone whatsoever, but then again, I didn't with the brylcreem exhaust either.
    I'll report back if there are any issues on the highway when I go to work tomorrow, or maybe take a quick trip tonight after rush hour, but I seriously doubt there will be any drone at all. Over all, this is an excellent buy and excellent system for those that want a nice sound with no drone, and something more subtle than say a Flowmaster setup.
    If you like it LOUD, this is not for you, if you like a nice tone with a little more sound than stock, get this system, especially for the money, it can't really be beat.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    1 BLOWN V8's Avatar
    1 BLOWN V8 is offline More Power
    Nov 2007
    Hemet/San Jacinto
    Quote Originally Posted by 89grand View Post
    Where did you get it?
    89grand's Avatar
    Phoenix, AZ
    I sent you a PM over at Custommagnums.
    2000 Jeep Wrangler
    LQQKOUT is offline LQQKOUT
    Jul 2007
    Abilene, TX (Dyess AFB)
    It will get just a little bit louder with time, nothing bad but it gets a nicer tone. What I did when I installed mine is: Before tightening the clamps I put a 1" piece of wood, metal spacer or what ever you have laying around the garage on the crossmember, than I bolted it up. This will keep the exhaust up and give it the proper spacing when you tighten the clamps. After everything is tight all you have to do is remove the spacer you added.
    GotMe-N-R/T's Avatar
    GotMe-N-R/T is offline www.mrdanageorge.acnrep.c om
    Nov 2006
    Medford, Long Island
    How's the drone on this? I currently have a JBA and hate the vibration. Anyone dyno with this catback? I don't expect to really gain any HP jus don't want to lose anythning. Can you guys put up a sound clip and llist what your other mods are?
    CURRENT MODS: AFE II Intake-PWR Heads and Cam-SLP Long Tubes-SLP UD Pulley-Borla 125s-Eagle Intake-NGK V Power Plugs-Moder Muscle Throttle Body-Mopower Chin Spoiler -BT Oil Catch Can-Innovate Wideband-Eibach Dampers-Hotchkis Sway Bars and Lowering Springs-SRT 8 Gears, Mopar TCM-Edge Racing Converter-TransZformer Shift Kit-Lows/Fogs HIDs
    89grand's Avatar
    Phoenix, AZ
    Quote Originally Posted by GotMe-N-R/T View Post
    This system has ZERO drone. I didn't dyno it, but I certainly don't feel like I lost anything at all, and I'm not sure I gained anything either.
    Hmmm, I'll have to figure out how to do a sound clip. I have a camcorder, but I've never downloaded anything from it.
    2000 Jeep Wrangler
    Crazy R/T's Avatar
    Crazy R/T is offline previously Black R/T 06
    Feb 2006
    South shore of Montreal, Canada
    What size are the pipes? I checked and didn't found the spec on their web site.
    06 Magnum R/T brillant black
    , JBA headers/mid-pipes, C&L CAI, Predator CAI 91 tune, BT pistol grip, Kicker audio upgrade, MSRT wheels
    bklynmag is online now Maggie under construction
    Brooklyn, N.Y.
    Does anyone know the muffler design? Are they straight through and/or chambered?
    5.7 Personal Best: 11.46 w 1.59 60'
    6.1 Personal Best: 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Coming Soon
    Mods: Busted 6.1
    Crazy R/T's Avatar
    Feb 2006
    From pics it seems chambered and look pretty much like Borla 112
    Crazy R/T's Avatar
    Feb 2006
    See this thraed for more info and vids
    Volant Cat-back
    Nov 2006
    Thanks for the link. I am looking for a quieter exhaust with less drone than the JBA
    Jul 2007
    This is the catback for you then.
    The muflers are straight thrue design.
