Results 1 to 11 of 11
    Fast56k's Avatar
    Fast56k is offline I ain't no FRI baby!!!
    Mar 2006
    Tuning with A/F from each cylinder
    I was looking into Innovate for Air Fuel today and they have a system that will measure up to 12 cylinders. I am wondering how this would be done. Would you have to weld a bung in each collector tube? I can see how this level of detail could be beneficial. I am thinking about getting the LC-1, sending the output to my narrow band SRT guage and then merging the data with predator data on the computer when fine tuning. I guess you can use LC-1s in the same way as the 12 cylinder gadget. You get one for each cylinder and monitor each cylinder A/F. If 7 other people want to get together with LC-1s, we could share them around and each get this kind of data.
    C.
    Silver 06 CSRT-8
    Redfox0099's Avatar
    North Charleston, SC
    sounds expensive.....in other words something a shop should try and let us common folk know how it went.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Great idea, but there just isn't enough space for the bungs, let alone the sensors and leads. At least no where I've seen. Don't get me wrong, I'd luv to see it happen.
    RobAGD's Avatar
    Reston, Va
    long tubes 16" from the ports Get creative heheheh
    -R
    Fast56k's Avatar
    Mar 2006
    Quote Originally Posted by Redfox0099 View Post
    Maybe a shop could make up a special set of bung heavy headers...
    C.
    Silver 06 CSRT-8
    Fast56k's Avatar
    Mar 2006
    The LC-1 isn't the same thing as the ST-12. However, 8 LC-1s could deliver the kind of data we need with 8 cylinders.
    C.
    Silver 06 CSRT-8
    Fast56k's Avatar
    Mar 2006
    Actually, I think we could get by with 4 of them. Just work on one side at a time.
    C.
    Silver 06 CSRT-8
    motoxxx's Avatar
    motoxxx is offline Got Boost?
    Feb 2007
    CT
    http://www.innovatemotorsports.com/x...cat=266&page=1
    This is the package we are talking about. Although it would provide you with extremely accurate data, at $2,500.00 its not all that practical.
    Mods: Arrington 426 8.8:1 comp., Power Ported Performance stage 2 heads, PPP blower cam, Paxton Novi 1500 blower, Custom frontmount intercooler(garrett core, 3in piping), Fore fuel hat, FPR, fuel rails, Earls -8 fittings and lines, Setrab oil cooler, Kooks headers, Magnaflow exhaust, phenolic manifold spacers, 180 t-stat, 22" Iforged aeros/yokohama advans, KW variant 2 coilovers, Hotchkis swaybars, Brembo cross drilled rotors, Stop-tech braided lines, Centric pads, Motul RBF600 fluid, Pro torque 2800 converter,DSS stage 5 halfshafts, Quaife lsd, 10 point roll cage.
    Blown7's Avatar
    Blown7 is offline LX Padiwan
    Well understand that A/F is a OK tool but by averaging all the bank side really isn't the correct way to tune. Actually tuning for individual cylinder EGT is the proper way to tune.
    A/F is for dyno where individual cylinder numbers would be impractical to do.
    I amuses me that everyone is still thinking they are safe when yet no one has proved to this day how the individual cylinders are running.
    Quote Originally Posted by SRTEngineers View Post
    More regulatory capability for diagnostics and feature content is typically what drives a new engine management system. Basically new name/new box...
    What is lost? Hackability.
    2007 Grand Cherokee SRT8
    THE DIGITAL MILLENNIUM COPYRIGHT ACT OF 1998
    yep the tuning is here.
    http://www.cherokeesrt8.com/forums/s...t=4504&page=36
    Fast56k's Avatar
    Mar 2006
    Quote Originally Posted by Blown7 View Post
    It amuses me that everyone is still thinking they are safe when yet no one has proved to this day how the individual cylinders are running.
    This is a very good point. Air fuel by cylinder can be way off. I was told it seemed one of my cylinders was getting hot and detonating when I had my car on the dyno causing knock retard for all cylinders. Turns out I have probably popped a head gasket at cylinder 7. Tuning each cylinder can point out intake air flow issues as well as injector problems which can invoke detonation and thus knock retard. Once you get all cylinders in line, then putting er on the dyno for power makes better sense.
    C.
    Silver 06 CSRT-8
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Well since your gona have the head off. Why don't you have the 1/8" NPT bungs welded in. That can be done and the bungs welded to the top of the header primaries where you can access and install the EGT probes and plugs when done.
