Results 1 to 15 of 24
    X E Ryder's Avatar
    X E Ryder is offline Open Course Road Racer
    Nov 2007
    Southern California
    Exclamation The Truth About The $9 +40HP E-bay "Chip"
    The Truth About The Fake “Chip”
    So you surf E-bay looking for mods for your car and come across a Performance Chip for only $8.99! and it makes 40 Horsepower! WOW! Wow? The only thing that should amaze you here is the brass some of these people have to make this claim. Here is one of these ads:
    http://cgi.ebay.com/ebaymotors/PERFO...QQcmdZViewItem
    Some money was deliberately wasted to see what the heck you get when you buy these, and the reality is pretty interesting. The Dodge Caliber and Dodge Charger “Chips” were purchased. In these tests, the units have been Weighed, Tested and Measured and have been found Wanting!
    You will receive a single page letter with a piece of bubble wrap on the back, and it contains a single resistor with a piece of heat shrink over the center so you cannot read the resistance value bands. A quick test with my Fluke multimeter revealed BOTH the Caliber and Charger “Chips” where the same, a 32.7 K ohm resistor.
    The direction sheet instructs you to disconnect your IAT Sensor plug, and bend the resistor legs into a U shape to jump across the connector. Once done you are instructed to Leave the IAT unplugged! This means you have now assigned a Fixed value to your IAT and it can never again provide Dynamic data to your PCM, it will Passively provide a Fixed Value Forever! But what value is that?
    The test Charger IAT out of the car, at rest, on a bench, in ambient temperature provided a reading of 14 K ohm resistance, the IAT plugged into the Charger that idled for several minutes and was fully warm under hood was 2.7 K ohm resistance. Let’s find out what these values equate to shall we?
    Connecting our Charger with a Predator programmer and cable to a Laptop using the Data Viewer function allowed a quick setup of a custom Data Log for the affected sensors. You can download the Data Viewer program free here:
    http://www.diablosport.com/CMR/softw...er_3.1.5.3.exe
    Then you can open this log file, and playback the recorded data of the sensors test that was made, here (note the file is zipped so it won’t try to open on download):
    http://www.xeryder.com/predator/IAC_Test.zip
    Logging revealed that this “Chip” tells your PCM that it has 32o F air coming into the engine, all the time. The test vehicle which sat idling through several tests, claimed the true air temp was 100o F. For accuracy, most drive tests of this sensor indicate about 70o F intake air temp.
    If you are wondering why this sensor was chosen to tamper with, the theory is that by faking out the PCM to think the air is that cold, it will richen the mixture up for the denser air. It is not a bad idea in theory, but in practice it does not hold up too well.
    X E Ryder - Laguna Seca 1:54
    rwalshphoto's Avatar
    rwalshphoto is offline Matte White Wagon
    Phoenix, AZ
    Wow thats a lot of research! Thanks for putting the time in, although I never really considered tampering with hundreds of dollars worth of PCM and sensors with a $8 ebay "chip"
    Super T's Avatar
    Aurora, IL
    Thanks for that writeup! It's been no secret how those Bull**** "power adders" work, but it's really interesting to see what number they actually toss at the PCM. As long as you have the resistors, I think it's dyno time!!!! ;-)
    Redfox0099's Avatar
    North Charleston, SC
    Don't feel bad...when we started with trying to tun these cars over a year ago we moved the IAT sensor inside the car into the A/C air vent to trick ti that way....if you don't try stuff you never know.
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by Redfox0099 View Post
    LMAO... don't remember reading that. Wow....
    X E Ryder's Avatar
    Nov 2007
    Southern California
    Cool
    Ha! too funny - yep - whatever it takes to get the power!
    I actually put my removed IAT in the ice try of my freezer and was UNABLE to get it to drop low enough to match the "Chip" resistor! I thought there had to be a sane reasosn they chosen such a high value.
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    haha nice!!!!
    BoiseHemi's Avatar
    BoiseHemi is offline KravMagaSpokane.com
    Spokane, WA
    So what was the final verdict?
    05 R/T: FRANK RACING ECONO HEADS: MILLED, PP FOR N20 & SIDEWINDER CAM w/custom push rods, 2 1/2" custom Borla pro, JBA headers & high flow mids, Modified Volant intake, Diablo w/FRI CMR, BT Catch Can, Zex Kit, NoESp., Functional MOPOWER SHAKER!!!!
    BEFORE FRI'd- 309RWHP/358RWTQ
    AFTER
    FRI'd- 360RWHP/385RWTQ
    AFTER DIABLO, NEW PUSHRODS, NEW TUNE, CRANK PULLY & PORTED TB- ????
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Quote Originally Posted by BoiseHemi View Post
    The "Chip" performed as advertised!
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    TxCowboy's Avatar
    TxCowboy is offline Ride my famous Murder Ride
    May 2006
    Spring, Texas
    Wow! thanks for taking one for the team their. I always wondered what they'd actually send you. Geez you could sell resistors for $1 with free shipping and still make a %90 profit. Beans for ya!
    feros's Avatar
    feros is offline Yellow the fastest color!!!
    Nov 2006
    Dunn, NC
    Great write up! Very nice. I guess I am headed to radio shack to buy a resistor...oh wait there is no radio shack for 1000's of miles here. Maybe another day. LOL!
    Pictures: wifes: "Beauty" and "The Beast" <--mine
    Two Chargers that beat as one.
    a fast car, ok the fastest color Charger YELLOW!!!
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    Yep, same thing proven with any car ever made. They don't work, yet people keep buying it.
    You can buy 200 of these "magic" chips for $3.82. http://search.digikey.com/scripts/Dk...name=33KQBK-ND
    Sucker born every minute.
    Mike
    06 Magnum R/T Midnight Blue
    da BoMM's Avatar
    da BoMM is offline Conspicuous Combustion . . .
    Spring, TEXAS
    Wonder why the Atty Genl doesn't squash these fake items???
    6.1L HEMI #622 '07 TorRed MSRT8 1/165= TORRED >< 6.1L HEMI '10 Silver Jeep GC SRT8=4X4JET
    MSRT8 owners http://www.lxforums.com/board/groups/magnum+srt-8+owners/
    Jaak's Avatar
    May 2005
    Quote Originally Posted by mhigham View Post
    Mike
    Group buy! LOL!
    2006 Magnum SRT8 - 11.85@117
    X E Ryder's Avatar
    Nov 2007
    Southern California
    Smile Well...
    It is not recommended due to sending a fixed value to the PCM regardless of whatever real world changes occur. It should not be used with a real Chip or Programmer, and there is no way in heck you would gain MPG from this thing tricking your PCM into dumping a rich mixture in.
    Based on this research, I am working on a dynamic IAT item that would be ok for a motor with no Chip available, like my gal's Caliber - hmm a test vehicle!
