Can we not have these on the Nags??And if we cant why not??Thanks
trans brake just opens the 1st gear and reverse solenoids at the same time, right?
correct. ^^^
i havent heard of anyone useing it on a lx car yet.
mopar 11
Corsa Hotchkis ...so far.
Call ATI, I know they have some prototype stuff forthe NAG's like Manual Valve bodies and stuff like that.
-R
Think of the crazy 60's if we could get a brake to work.However with a set up like that you will find your weak links if you want to or not![]()
probably because the TCM will see the pressure switches and go in limp in. something for TCM tweaks...
AFE CAI, SLP LM II, ZEX 100Shot, Nitrous Oulet Plate , Mopar LT's/cats,Inertia Motorsports Perf. Heads & Spartan Cam -Ported 6.1L Oil Pump (Installed by Matt @ Michigan Hemi Performance)No-ESP mod, Predator Tuned, TEIN SS Coilovers, 20" Viper Replicas (custom powder coated)CMR Tune by Johan @ Diablo Sport
yep. someone can try it, but i bet the tcm will flip out.
ATI??????
Why would you not call Eddie at Southern Hotrod or myself?
We are supporting vendors that have PRODUCTION pieces....NOT prototype. Geez.
Oh....with the help from AJ here a trans brake should be available next year.
Probably want to put an explosion blanket around the NAG1 with this mod though.
Bill
Bill, I happened to know that as of the Atco NMCA event that had done the Manual Valve body and some other things to the nag1 ( 722.6 I think )
I had not heard you all had done anything along those lines.
-Robert
Manual valve body would almost make me consider keeping this trans...
Bill and I have discussed this in legnth before I had ever seen these forums LOL. I have one here. The only thing is it needs alot of testing. I hoped to have a nag in the Stratus however the budget doesen't allow it. Im using the trans I built 2 years ago. We will get it going for sure. The trans will take it for sure. I would have no worries with a brake. Its actually eaiser on it than you think.
Hope this helps
A.J. (HEMITUNER)
Wait, someone produces a manual valvebody already?
