Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By fireman2118
Thread: Thermostat, fan mod, CAI - want to get up to speed quickly - apologize in advance
    moparmaniacc is offline LX Newbie
    Jan 2012
    Northern VA
    I want to get going on a mod this weekend, and am overwhelmed with all these posts. I apologize if my questions below have already been answered.
    1. Which thermostat is best - 180, 4127? I'll be 99.99 percent street, almost no strip action. Live near Wash DC.
    2. Which fan mod is the best? Some look like they are no longer being made.
    3. I want to buy a CAI - so many to choose from - is AirRaid a good one?
    4. All I've done so far is buy a Diablo Predator and did a 91 Octane tune.
    thanks in advance!
    - John
    done's Avatar
    done is online now Hanging out for 8 years
    Old Hickory, TN
    1. Any 180 will do. You can drop the fan on temps by 15* with your predator.
    2. Don't bother, fan mods are really only useful at the track.
    3. Anything from LMI will be the best choice, the AirHammer is a very good value.
    4. Good start.
    Mar 2008
    You'll find that even with a 180 t-stat, the temps can climb to over 190 in stop and go driving and on warmer days. You already have a Predator, so you don't need a fan mod. You can use it to adjust your fan speed temperature settings to work with the 180 t-stat.
    kenmc likes this.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, MMPG stage 1+ ported 6.1 intake & 85mm throttle body, LMI 4" true CAI, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, Tranzformer shift kit, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE, Vossen CV3s & Nitto 420s, tuning by Robert Dito of Ditos motors
    Jan 2012
    Northern VA
    Quote Originally Posted by fireman2118 View Post
    Thanks for the quick answers guys. Two questions:
    1. For some reason I am not seeing the menu in my Predator to change fan settings. I see where I can choose from about 5 tunes, plus shift firmness, plus fix speedo if I changed the gear ratio, but no fan settings.
    2. The LMI Hammer CAI looks good. Is it louder than most CAI? I seem to attract cops for some reason. What is one of the quieter CAI.
    Thanks
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by moparmaniacc View Post
    Thanks
    1. Fan settings are in Quick Adjust after you load a performance tune.
    2. AirHammer is the loudest, but only when you floor it. It will never disappoint. Go with the best.
    Hal'sMag is offline 06 Magnum R/T
    Feb 2007
    L.A., Ca.
    Build your own CAI like the Frankintake IV for half the price, and have some fun doing it.
    Just a grocery getter!
    BadAssSRT8 is offline I'll Spend All Your Money For You!!
    Mar 2010
    Out In The Country
    LMI is the way to go for CAI's. Hands down, the best most productive CAI on the market & Chris there is tops.
    LMI V2 True CAI, Sprint Booster, DS Catch Can & inTune, Magnaflow Everything, VIP Edition Rear Window Spoiler & Bentley Head Light Covers & AVS Low Profile Side Window Vent Visors, E&G Classics SS Mesh Front Grill & Front Brake Air Intake Grills, Polished SS Rad Cover, 180 JET T-Stat, MSD Coils, StopTech SS Lines, Demolded, Aftermarket Audio, 6K HID Lows & Fogs, Smoked Side Markers, Tinted Taillights, Razors Edge Strut Brace, SRT Pedal Set, Whiteline Sways, Hop Not Engine Torque Strut, Paramount Stage II VB, ATI 13% UD Damper, 392 Fuel Pump, MMP 87mm TB, B&M Hi-Tek Cooler, 6-spd Engine Mounts
    Jan 2012
    Northern VA
    OK,
    Today I installed the 4127 170 thermo, dropped all fan settings 20 degrees using predator, and it still climbed to 203 today (i think it was hitting 215 before). Is that good enough?
    legmaker's Avatar
    legmaker is online now LMI Intakes....CF intakes for LX/LC
    orlando, fl
    make sure your fans are turning on. if it is really hot out, and you are sitting in traffic, it is reasonable to see that even with a 180 t-stat. Just make sure the fans are operational and your setting are low enough in the predator to go along with the new lower t-stat. i use to set my LS fan setting at 180 and my HS fan at 185
    as for the CAI, shoot me a PM and I can help you out. I have a few offerings for your car, but the Hammer is one of my favorite!
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
    done's Avatar
    Old Hickory, TN
    OK,
    The fan settings and thermostat should keep you in the low 190's. Did you get all the air out of the system when you changed the themrostat and are you sure both of your fans work?
    EricG is offline LX Guru
    Jul 2007
    Albuquerque, NM
    You might be watching the oil temp and not the water temp.
    '12 Challenger SRT8 Pitch Black 6-speed, stripe delete, all options
    -BT catch can, skip shift eliminator, K & N drop in, BB's resonater delete, Jet 180 t-stat, ceramic tint/clear bra
    13.56@104.38 DA 7170 - that's 12.33@114.45 corrected!!!
    JTSRT8's Avatar
    JTSRT8 is offline LX Guru
    Sep 2011
    South FL
    Yeah, mine are all 20 degrees lower then stock & the car gets to 197 on a typical hot & humid FL day in traffic. But once I get moving it goes down, & the fans do kick on while I'm sitting so it still never gets above 197.
