Page 16 of 16 FirstFirst ... 6141516
Results 226 to 236 of 236
  1. #226
    Cam's Avatar
    Cam
    Cam is offline effectiveness is not always pretty
    Oct 2005
    Riverside, Ca
    Busted a spring huh. Bummer.
  2. #227
    Jected's Avatar
    Jected is offline Aussie SRT8
    Melbourne Australia
    PSI's the only way to go IMO. I think R is now running them as well (at least I hope he is). Shouldn't have happened to him.
    426 WHIPPLE 3.4L BLOWN 300C SRT8
    http://www.lxforums.com/board/signaturepics/sigpic14184_6.gif
  3. #228
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    Anything planned for the fuel system other than Boost a pump? Curious, as I seem to be running out of fuel with just boost. I just broke down today and decided to get serious about it but I am not wanting to compromise the stock engineering at all. I have science'd out a parallel system to work with the stock baskets. Any thoughts on this matter?
    Chris
    Stupid Nasty.... FBG 2.0 9.59 @ 148
    FBG 3.0 underway.... Arrington Aluminum 440/Vortech XX trim /4.2KB /Turbo/Nitrous testing in progress
  4. #229
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Quote Originally Posted by HEMI~C~ View Post
    Chris
    Get a hold of SharaDon I think they have been putting 2 pumps in the baskets
    Video
  5. #230
    RandysWay's Avatar
    RandysWay is offline <- Bucky the Mango!
    Nov 2005
    Southern California
    Chris
    Hi Chris,
    I'm running a drop-in Walbro 255 Fuel Pump with NO KB Boost-A-Pump, along with 63lb Injectors. So far it has been just fine, although I haven't been able to test it much yet. I'll know sooner once I start driving it when it's tuned, and that if she starts running out of fuel at the top end on the dyno.. but I don't think she will. If it has troubles starting with a low fuel amount, I'm going to drop in the factory fuel pump in a second basket to pump into the main basket that the Walbro is housed in.
    I'll know more once she gets tuned, which should be by the end of the week.. and I'll keep all of you updated on my findings.. just remind me.
    -R
    Sweet Mango Modern Mopar Muscle with an old school twist
  6. #231
    lallend's Avatar
    lallend is offline '63 Buick Riviera
    Dec 2006
    Sin City
    Quote Originally Posted by RandysWay View Post
    The only thing we need to iron out is getting her into gear.. with the high stall converter, it's VERY hard to get it into gear because it's untuned.
    This is strange, care to elaborate?
  7. #232
    HEMI~C~'s Avatar
    Oct 2004
    drop in Walbro you say?
    Hi Chris,
    -R
    Hmmmm, whats this about a drop in Walbro??? I have looked everywhere and can't seem to find one that has the same type of feeds on the bottom that will connect to the bottom of the basket like our stock one does.....or connect to the factory outlet for that matter. I can easily find a way to connect the pump to the fuel line but how did you get around the fancy plastic fitting and one way flapper on the bottom of the basket? Without the flapper, the basket does not fill....without the special plastic fitting you don't draw any fuel from the driver side tank. Please enlighten me.
    My solution was going to run a second walbro strapped to the outside of the basket...sucking off the floor of the tank....feeding a into the pass side basket. It gets much more complicated from there but I am curious as to what exact pump you went with?
    Thanks,
    Chris
    Thanks,
    Chris
  8. #233
    1SRT8-2NV's Avatar
    1SRT8-2NV is offline My fuel mileage sucks!!
    Mississippi
  9. #234
    dgreekman's Avatar
    dgreekman is offline LX Newbie
    Thanks,
    Chris
    Thanks,
    Chris
    Was this ever answered?
    K-1 Technologies 426 Stroker kit, Custom Wiseco inverted dome pistons, port & polished heads and intake, custom grind Comp 426 cam, Polished T-Trim Vortech supercharger, Kooks Longtube headers with flowmaster exhaust, CPR Fuel rails, Walbro 255 fuel pump, MSD Ignition, ARP mains and studs, ATI Balancer, DSS 1000 HP ½ Shafts, LSD, custom Vaca Performance Tune, KW coilovers, Hotkich sway bars, Asanti 3-piece AF-403, polished and anodized engine bay, RK Sport Heritage wing, Alpine and JL audio system, AAC Oracle Demon Eye headlights, tails, and HID Conversion
    www.projectsrt.com
  10. #235
    Redfox0099's Avatar
    San Antonio, Tx
    Never seen the car after this.... guess he drives the Lambo too much now.
  11. #236
    CT-MSRT's Avatar
    CT-MSRT is offline Supporting Vendor
    CT
    Quote Originally Posted by Redfox0099 View Post
    poor guy, must be rough...
    Current mods: Hi-Flows, 180. Volant, PS Cooler, Trans Cooler, SS Brake Lines, Ti Backing Plates.
    Pedders Track II Extreme, Wavetrac, Moroso oil pan/catch can, 6.1 MTCM, Mopar trailer hitch.
