Results 1 to 15 of 15
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    SuperChips 1/4mi VS Track 1/4mi?
    For those of you with superchips how far off was the superchips when you ran the 1/4 vs running at a real track?
    I ran 14.25 at 100mph with 5.72sec (0-60) My fast 0-60 was a 5.34 useing the charger own timer. Im starting to feel the 07 suck, mine seems slow compaired to others.
    Any one eles know there 1/4 mile time with a stock charger?
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    The SC time will be pretty close. The MPH will be high since the track averages the last part of the run. SC will read about 2-3 MPH high.
    The DashHawk does the same since neither has averaging like the track.
    Mike
    06 Magnum R/T Midnight Blue
    Shelby's Avatar
    Shelby is offline LX Padiwan
    Jan 2006
    Those times sound fair. You need to consider the temperature, pressure and humidity to compare numbers.
    I have an 05 Magnum RT and here are some numbers from the Datalogging thread ( http://www.lxforums.com/board/f127/datalogging-thread-posted-numbers-36203-post736898/ post 102):
    Here are 1/4 miles times and a comparison with the SC flashpaq data logging numbers (last run).
    2005 Magnum RT
    Stock tires were about 35 psi all around
    Launches were all with ESP on and launch from idle
    * numbers probably would improve if launched at 1100-1200 RPMs
    SC FP with 91 tune ( 93 octane fuel), reduced torque management, stock shift points
    Tried both "D" and paddle autokick (results the same)
    Conditions:
    75 degrees
    55 degrees Dewpoint
    pressure 30.26
    55% humidity
    Alt 152ft asl
    calc Density altitude 1025 ft
    The 3 runs on the 1/4 mile:
    14.298 @ 96.81
    14.321 @ 97.09 +0.023s (+0.16%) +0.28MPH (+0.28922%)
    14.312 @ 96.89 +0.014S (+0.0979%) +0.08MPH (+0.08263%)
    Remarkably consistent times and speeds.
    Corrected for conditions using
    http://members.tripod.com/~MY5LTRLXCPE/altitude.html
    Sea level conversion (1200ft - 0ft)
    ET * 0.9874 = 14.118s (corrected)
    MPH * 1.0129 = 98.342MPH (corrected)
    Not bad- not too good.
    Raw numbers from the track (last run had SC Flashpaq running for comparison):
    Run 1:
    rt : .615
    60 : 2.121
    330 : 6.011
    1/8 : 9.194
    MPH : 76.64
    1000: 11.966
    1/4 : 14.298
    MPH : 96.81
    Run 2:
    rt : .189
    60 : 2.126
    330 : 6.022
    1/8 : 9.210
    MPH : 76.61
    1000: 11.985
    1/4 : 14.321
    MPH : 97.09
    Run 3 real (flashpaq):
    rt : .276
    60 : 2.120 (2.43 31 MPH)
    330 : 6.019 (6.33 61 MPH)
    1/8 : 9.209 (9.54 77 MPH)
    MPH : 76.56 ( 77 )
    1000: 11.979 (12.33 88 MPH)
    1/4 : 14.312 (14.66 96 MPH)
    MPH : 96.89 ( 96 )
    Flashpaq was close on MPH but slow on the times:
    14.6% on 60'
    5.2% on 330'
    3.59% on 1/8
    2.90% on 1000'
    2.43% on 1/4
    The error keeps getting smaller, but 2.43% on the 1/4 makes the time look bad.
    Columbus Ohio
    When I first got her home she was running 6.80 o-60 times. I have done a lot of mods I don't really dont want to get into. But after mods the fast 0-60 times was 5.43. ESP off, launch 2000rpm not tire spin in D. I have put over 700 miles since all my mods. Factory tires 32 pounds, coolit mod running a constent 185 temp, I love the road,deep groves for loads of tracion. I just dont get it, my 07 seems so slow comparded to others.
    mhigham's Avatar
    Feb 2007
    Michigan
    Not sure whats going on. You took a second off your 0-60. A second off the 1/4 mile puts you well into the 13's.
    I have been running 13.7 consistently (no nitrous), but not sure how our mods compare.
    Mike
    mikespy's Avatar
    mikespy is offline Fastest N/A 5.7L Magnum around!!! SOLD!
    Houston
    Get used to her she'll come around.. and you'll be running 13's when you take her to the track. Remember... the superchips runs the times off of your tire settings also. Check those out and find out what your 60fts are.
    2010 SRT8 Challenger...
    MODS: Magnaflow Competition exhaust, Roto-Fab CAI.....
    formerice's Avatar
    formerice is online now LX Guru
    Dec 2004
    maine usa
    These cars really like cool air, Bet you'll get much better times than that come winter. If it makes you feel better, I was stuck in 2 feet of snow third week of April, but she was running like a beotch until that last snow drift!
    hemi_charger_RT's Avatar
    hemi_charger_RT is offline Its got a hemi
    MD
    13.808 in a stock 07 RT with RT group option
    i had a low temp thermo/fan mod but i still considerd it stock
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    #1. its hot outside
    #2. you live in Texas
    #3. its only getting hotter
    #4. its not only hot but its wet and hot
    #5. its so freek'in hot i think I'm going to freek'in die out there!
    #6. its slow compared to what?
    #7. if you shock the ESP system, be prepared for the TB and brakes to take over.
    #8. No way can you launch @ 2000 and not spin.............if so, you have huge ESP issues.................bottom line
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    Don't worry Mike, my car is a pig right now too.....too much heat and moisture to do any real good. I did murder an 06 mustang gt the other day, but that's not saying much really.....did piss him off he got smoked by a 4 dr!
    MomsR/T's Avatar
    Houston
    yeah............but thats the point..............ALL the cars are slow right now; so you have to keep things relative.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by MomsR/T View Post
    Yup, relative humidity...........98%, have a sweaty day.
    MomsR/T's Avatar
    Houston
    ROFL.......................dude, you have no idea.
    Steve and I were working yesterday afternoon and it was so sticky it was almost dangerous. Its been 90+ degrees for a couple of weeks now and it will stay that way till Sept.
    Couple the 90 - 105 degree temps with 70%+ humidity and everything will run slow.................
    Its Houston.................its been that way since the gringo came and will be that way long after we're gone.
    mikespy's Avatar
    Houston
    Aw come on you sissie's i'll race you all!!!
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    Lee I feel your pain...try doing any type of yard work in Corpus B 4 6pm and ur askin for a tripto the ER w/a nice farmers tan!
