I am lucky and have my bottle in the rear in the tire well....can't see that. As far as the controller I put it in the Volant box under the filter you can't see it at all. I covered the lines with split vacume hoses so even if you are looking you can't see them very well. I had some guy ask where they were one time...had to point them out.
As far as the switches I ran all the switches in the cup holder and made a custom plate to put them in. If the cup holder is closed you don't see a thing.
I put the purge underneath the air box and mounted it to the frame can't see it without taking off the cover underneath the car. I then ran the lines when I had the bumper cover off across the bumper frame and underneath the wheel well covers. I then cut out a small hole and poked the line through and painted them black. When I hit the button it sprays out both fender wells up in the air at and angle. Here are the pics I took of the install. Sorry no pics of the purge lines.
05 R/T: FRANK RACING ECONO HEADS: MILLED, PP FOR N20 & SIDEWINDER CAM w/custom push rods, 2 1/2" custom Borla pro, JBA headers & high flow mids, Modified Volant intake, Diablo w/FRI CMR, BT Catch Can, Zex Kit, NoESp., Functional MOPOWER SHAKER!!!!
BEFORE FRI'd- 309RWHP/358RWTQ
AFTER FRI'd- 360RWHP/385RWTQ
AFTER DIABLO, NEW PUSHRODS, NEW TUNE, CRANK PULLY & PORTED TB- ????
