Results 1 to 9 of 9
Thread: srt resonators
    typhoon4x4 is offline Banned
    queens nyc
    srt resonators
    im curious what the pipe diameter of the stock srt exaust? i was thinking of adding the srt resonators to my charger to cut down on the drone .
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Quote Originally Posted by typhoon4x4 View Post
    Actually, Vincent, the drone would be increased. Erik (Hemi31) put his SRT exhaust on his wife's RT and it was worse. They are designed differently, with the RT resonators being 'tuned' to cancel out the MDS sounds.
    John Y
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by JonzMgnm View Post
    I've got the SRT exhaust on my RT, and there's absolutely no drone whatsoever. At cruise speed, it's as quiet as my original stock exhaust. Idle, and WOT however, are much deeper Although, I don't have MDS anymore, so I could be mistaken....
    I'm fairly certain that the resonators are the same on all LX's. The diameter on the SRT resonator shrinks down to a 2.25......
    440 Stroker Short Block 4sale!! (tentatively sold)
    2010 MSHS Stroker N/A Champion!
    PowerWagon896's Avatar
    PowerWagon896 is online now Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    Quote Originally Posted by MadCharger View Post
    The pipe diameters are 2 1/4" for the R/T (catback only the cats are 2 1/2") while the SRTs are 2 3/4". Indeed the pipes do shrink down @ the suitcase & resos, you could weld them on, but you will not be able to do a "slip fit" connection.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    You have a Charger just as Dan does.Maggies are much more susceptible(sp)to drone since the rear interior is like the inside of a drum.You have alot more insulation with a Charger.
    BFNY PERFORMANCE
    RIP My Friend
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    This is true - but I'm fairly certain this system is as quiet as my original system (road & track) at cruise speeds. It's almost dead silent, even with the rear seats folded down. I think I also read somewhere that the resos on both systems are the same. At idle, the SRT system is MUCH louder than my RT system was, which I attribute more to the 1/2" larger diameter tubing, and not the resos. It's very possible though that if I had MDS, it could be different.
    youngceez's Avatar
    youngceez is offline LX Newbie
    run straight pipes and resonators, sounds good no drone!
    2007 sublime Daytona # 1080 removed moldings, 18% window tint, 22" dropstar ds02 6" lip, 265/35/22, straight pipes and resonators
    May 2006
    Boy Howdy do the SRT8 only "Blastin Bobs" DRONE!
    It's not so bad except between about 1800 & 2200 RPM when it drops out of MDS & starts pulling hard on all 8. (like going through the Adirondac) I was dropping the trans into 4th gear. The revs get up above 2200 & It does quiet down.
    I'm going to try an old Harley Davidson trick & put some adjustable washers in the tips for hi-way cruise situations.
    Hemi31's Avatar
    Yes....with MDS disabled I was happy with the SRt exhaust on my 5.7......but as sooon as the MDS kicked in.....OH BOY was it awful!Sounde like a buzz bomb!
    BFNY PERFORMANCE
    RIP My Friend
