srt injector help
i cant find my frickin manuel its been mia since the body shop.i put it in a secure place until my car came back well its so secure i forgot where it is(i know i aint the only one this happened too).so if someone could look up which relay in the pdc controls the fuel pump relay .thanks srt injectors are going to be installed by days end the lx manuel is awesome.
Humm your going to be running stupid rich with the SRT injectors, why are you going with them ? DO you have Heads and Cam ?
-R
ok here are my results of the switch .she does not seem to like the srt injectors black smoke and rough idle very rough on the verg of dying does not accelerate passed 2 k rpm and once in drive sputers and dies :( the lightning bolt in parethasis flashes constantly.im guessing its a no go untill heads and cam :(...... is there 0 anything i should do to make sure its not occuring because of pressure loss im sure i did it right.i followed the dcx manuel to the tee.
- You may not post replies
- You may not edit your posts
Forum Rules
