Results 1 to 15 of 30
    snickle's Avatar
    snickle is offline LX Old Timer
    May 2004
    Speed Density vs. Mass Air and performance with intake mods.
    A good (if brief) article on Speed Density and Mass Air EFIs
    http://www.carcraft.com/techarticles/24549/
    Explains some of the comments that we won;t get improvements with a cold-air kit. And why we do.
    Basically, the computer looks up the fuel value in a large TABLE based on engine speed air, temp and manifold pressure. Changes in the intake cause these values to be wrong. An 02 sensor in the exhaust measures remaining oxygen in the exhaust and the computer tries to compensate.
    So we will get improvements, but I bet we could easily provide more air than the system could compensate for.
    So mild intake changes are probably best until someone reprograms the system for us.
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Good article. FROM what I have read FROM the service manual it appears to me that the computer in our cars actually calculates the values. Here is the first paragraph of the section about the PCM:
    "The PCM operates the fuel system. The PCM is a pre-programmed, triple microprocessor digital computer. It regulates ignition timing, air-fuel ratio, emission control devices, charging system, certain transmission features, speed control, air conditioning compressor clutch engagement and idle speed. The PCM can adapt its programming to meet changing operating conditions."
    That last statement is one that makes me believe that the values are calculated or that there a great deal of room for adjustment automatically by the computer. There are also many "modes" of operation that the PCM runs under. Depending on what mode it is in determines what sensors it looks at and which ones it ignores. The service manual is pretty interesting. It gives some good insight INTO how our PCM operates.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    snickle's Avatar
    May 2004
    It calculates adjustment to the tables. SInce this is a speed density system, it can't totally calculate the values, as it has no DATA on how much air it is really getting.
    2005 Dodge Magnum RT - Midnight Blue Pearl
    Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
    SXT Headlights, MDS Monitor, Bel 975R,
    Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
    Jun 2004
    Evans, GA
    Ahh I see said the blind man. I wonder how much room they left for adjustments?? Only one way to find out..... Modify modify modify and test to see the results.
    C4me is offline LX Padiwan
    May 2004
    Ohio
    OK, think Denver in the summer, then think uhm someplace low and cold in the winter. There HAS to be a wide range of values available.
    C-Man's Avatar
    C-Man is offline 2005 300C Man
    Jun 2004
    Palm Harbor FL
    Here's something I pulled out of the service manual
    MODES OF OPERATION
    As input signals to the Powertrain Control Module (PCM) change, the PCM adjusts its response to the output
    devices. For example, the PCM must calculate different injector pulse width and ignition timing for idle than it does
    for wide open throttle (WOT).
    The PCM will operate in two different modes: Open Loop and Closed Loop.
    During Open Loop modes, the PCM receives input signals and responds only according to preset PCM programming.
    Input FROM the oxygen (O2S) sensors is not monitored during Open Loop modes.
    During Closed Loop modes, the PCM will monitor the oxygen (O2S) sensors input. This input indicates to the PCM
    whether or not the calculated injector pulse width results in the ideal air-fuel ratio. This ratio is 14.7 parts air-to-1
    part fuel. By monitoring the exhaust oxygen content through the O2S sensor, the PCM can fine tune the injector
    pulse width. This is done to achieve optimum fuel economy combined with low emission engine performance.
    one_raven is offline LX Padiwan
    Jul 2004
    Quote Originally Posted by snickle
    Are you sure about that?
    I'm not saying otherwise, just checking if you have the specs FROM anywhere.
    If a vegetarian eats vegetables, what does a humanitarian eat?
    snickle's Avatar
    May 2004
    Every review I have read on the engine has called it such and no MAF sensor that I can find. So it has to be a Speed Density setup, unless someone has invented something new.
    Jul 2004
    That's enough for me, thanks.
    I just wasn't sure if you were basing it on the article saying that most Mopar engines have Speed Density.
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    well, in the end, someone is going to have to come up with higher flow injectors. I would bet my sister in laws underwear that the stock injectors wont be good for more than about 20% over stock Horsepower ratings.
    And the dead shall walk
    Jul 2004
    Quote Originally Posted by HammerFoot
    I think you'll have to post a picture of your sister-in-law before anyone will take that bet.
    Is that her in your avatar?
    7thS0N's Avatar
    7thS0N is offline She's done heck darnit!
    Tampa, FL
    Performance: AirHammer, Hi-flo cats, Bassani exhaust, Predator tuned, Mopar perf springs, Hotchkis sways, BT catch can, EGR delete
    Interior/Looks: Custom embroidered Katskins, custom embroidered console & cargo covers, tinted tails (Charg-um), Upper and Lower grills (NC-SXT), 'Cuda stripes, 20" Torque Thrust-M's, MoPower Shaker, MoPower Chin spoiler, PAINT!
    Tunes: Pioneer F90BT, JVC Arsenal KS-AR8004D + Kenwood KAC-7204, Infinity Reference setup including 2 10" subs in custom embroidered RobbyHo enclosures
    May 2004
    Ohio
    Uhm, and a 20% increase won't make you smile? Just what do you want/need?
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    I am prone to my excesses, I want as much as I am able to squeeze out and still maintain some reliability and driveability. I am thinkinnnggg, oooh, about 500hp at the wheels would be a good, happy medium.
    As for my sister in law,
    http://www.chinaeastwind.com/trailer...gly****er2.jpg
    Take your chances!
    HAHA!!
    bigdaddyoc is offline Do work!
    May 2004
    Corona, California
    LMFAO....nice hammer...just what I needed to get a laugh outta me.
    '11 Charger RT Plus- Bright White
    22" II Crave wheels (USW's soon) LMI Hammer intake, 85mm BBK, Mopar Strut braces F&R, Corsa Sport exhaust. Trufiber CF hood, KW coilovers, BT underhood treatment, Custom engine bay covers/paint. Coming soon... ICE and a few more suprises from vendor R&D....
    RETIRED -'05 Black Magnum RT
