Results 1 to 15 of 15
    KILLERBEE is offline Banned
    Dec 2007
    NYC
    Something Weird Happened
    DRIVING the car last night while approaching a red light .i stop rather abruptly.....the car idle went a little wacky and then died ?.......started her back up all was fine no codes nothing. running fri heads and cam and diablo.any ideas it was about 10 minutes after start up the car was warmed up too .didnt do it after i have had idle surge a few times.at least when coming to a stop ? the idle will surge then act like it wants to die then the rpm jump back up.really weird?
    cbloveday's Avatar
    cbloveday is offline My Friends Call Me "C Love"
    Jul 2007
    what diablo version you running? 16 has idle surge. 17 corrected. Check for exhaust leaks. Leave more room to stop.
    2006 300C SRT8 Silver *SOLD*
    BES P&P Heads,BES Intake,K&N CAI,BES CAM, Kooks LT CC Headers,HiFlo Cats,2800 TC
    ,Magnaflow Catbacks,Brembo CD Rotors, Braided Lines,Hotchkis Sways,DC Strutbar,BT Catch Can,Vellano VSY Rims,Mopar Chrome,Mopar Grill,,K40 radar,SRT8 Illum Sills, Dyno Steve Tune,
    LM-1,Alarm/Starter
    2007 Escalade ESV Black Raven
    2007 BMW M6 Black Sapphire Metallic
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    I had a similar issue with Diablo (running rev 18) I bumped my idle up by 50 rpm and no problem since..
    with the canned 91 octane tune my idle was around 530.. too low, especially in the cold..
    now it sits at 580 - 590 with the 50 rpm bump and is fine..
    alex3dworld's Avatar
    alex3dworld is offline BLACK CHARGER
    Sep 2007
    Miami
    if you look in our forums there is a lottttt of people with the stall problem, just make a search for the word stall, and maybe you can find your awnser,
    i had that problem when i was running stock, when i got the diablo i start playing with all the features to run my car as cool as posible (fan settings) and i rised the rpm of the car in idle (also thanks to diablo) 200 rpm up
    that makes the car almost imposible to shut down.
    i also run now, bigger headers, a CAI and a catch can, so...i can tell you exactly how i errased the problem but is gone
    i used to stall twice a month
    Diablo Predator-Mopar CAI-Mopar LT's-Mopar Sway bars-Mopar KW suspension-CTS covers & Ventshades-Mopar Rear Spoiler-Ceramic tints-BT c/can-180Tsat-Mopar decals-Razor Edge front & rear Moly steel braces
    TorRed #1179's Avatar
    TorRed #1179 is offline 1st Full Weight 5.7 in the 11's!!!
    Pasadena, MD USA
    Like said above, that is an ongoing problem. I still think its some sorta vacuum leak, but it does get better by upping the idle a few.
    2006 Dodge Charger Daytona R/T - TorRed #1179 - Fully Loaded
    HHP Stage 3 Heads & Cam, CMR Tuned by HHP, Mopar TCM, PI 2800 Converter, SRT8 Quaiffe Rearend w/ 3.23 gears, 09 Hubs & Axles, Dynatech Longtubes, SLP LM2 Catback, Arrington CAI, SLP Underdrive Pulley, & much more...
    11.843 @ 115.82 MPH - 12/12/09 Cecil County - 4378 lbs - 435 HP & 432 FT LBS TQ STD
    Dec 2007
    NYC
    well thats just what i did .i bumped it up to about 750 and version 18r is the version im running ? its just weird thats all .im getting cmr tuned in a few weeks and well see what happens
    Kim Hufty is offline LX Padiwan
    Southeast Mi
    I have the same problem at R18 with idle at 700.
    get initial surge at startup and it wants to stall on a fast stop. normal stops no problem.
    SHAKER check, Heads check , Cam check , tuner check, CAI check, LT 's check, Borla check, ext, ext, ext
    12.8358 @ 108.46
    Dec 2007
    NYC
    yep same thing here . hopefully diablo will chime in
    moonstreaker is offline LX Guru
    NJ
    The idle RPM is definitely set to low out of the box. I bumped mine 100 rpm's with the DS even though I never had stall issues. But the idle surge you are describing before stall definitely scream vacuum leak. When you get that surge and you think it's about to stall start pumping that brakes, that should give you enough of a vacuum boost to keep it from stalling out. Good luck.
    MVP25's Avatar
    MVP25 is offline UndertheRadar
    Westchester, New York
    KillerBee-
    Do you have a cam or other mods? I have a cam with stage 2 and had the same problem. I raised the rpm's at idle in Park and in Drive. Never had a problem since.
    Good Luck.
    PPP-Tech is offline Banned
    Feb 2007
    Muscle Shoals, Al.
    the problem is in the tune. When you put a cam in the car, the vacume drops causing stalling. The tune should be revised to help offset that. The brakes on the car operate off of vacume also, so when you hit thee brakes hard enough and take all the vacume out of the engine, you will experience some stalling if you have an aftermarket cam. This is very normal and not Diablo related, but cam related. Your tune should be revised to help compensate for the loss of vacume with the cam.
    Dec 2007
    NYC
    the plumbing for the turbo are they being instaled with stock exaust diameters in mind ? if you have the headers and hiflow cats and catback how would that work ?
    Feb 2007
    Muscle Shoals, Al.
    catback comes off of the car, the system will work with some headers, but we do not have a list yet. The turbo works with all shorty headers.
    Dec 2007
    NYC
    So Jba Shorties And Jba Hiflow Cats Are Good ?
    BoiseHemi's Avatar
    BoiseHemi is online now KravMagaSpokane.com
    Spokane, WA
    I have this stalling problem myself and I don't have the Diablo yet just the SC. It is kind of a pain in the butt and I am hoping that with the Diablo and a good tune I won't have to be careful how fast I stop.
    05 R/T: FRANK RACING ECONO HEADS: MILLED, PP FOR N20 & SIDEWINDER CAM w/custom push rods, 2 1/2" custom Borla pro, JBA headers & high flow mids, Modified Volant intake, Diablo w/FRI CMR, BT Catch Can, Zex Kit, NoESp., Functional MOPOWER SHAKER!!!!
    BEFORE FRI'd- 309RWHP/358RWTQ
    AFTER
    FRI'd- 360RWHP/385RWTQ
    AFTER DIABLO, NEW PUSHRODS, NEW TUNE, CRANK PULLY & PORTED TB- ????
