Results 1 to 4 of 4
    I fly 2's Avatar
    I fly 2 is offline LX Padiwan
    Bolivar, MO
    Sending Data Log For Email Tune
    I did some data logging the other night and everything seemed to go o.k. I watched the playback and saved the data. The problem is that I tried to email the tune to Steve at RDP and he said that he was unable to read the data log. Any ideas on what I did wrong.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Try zipping it first. There was problem in the past with none zipped files getting corrupted.
    I fly 2's Avatar
    Bolivar, MO
    I saved the data on a flash drive, so should I try to send the data from that?
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    find the saved tune file.
    right click on it.
    scroll down to "send to"
    select "compressed file"
    this will "zip" up the file to a smaller size so it can be more easily emailed etc.
    try sending it that way.
    do this to a copy. never zip an original file or remove your first copy, just to make sure you never damage or lose an existing file
