Results 1 to 15 of 17
Thread: Roller Rockers?
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    Roller Rockers?
    Has anyone made them available yet? I can't stand my rockers, having some real problems with them being very loud, so i'm looking for an alternative.
    Thanks
    Bill
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Quote Originally Posted by tank8289 View Post
    Thanks
    Bill
    I've been looking for them too. So far no luck. From what I understand the roller rockers would require other changes like different valve locks since the rollers would require more surface area. Anyway, I'm still looking.
    HoonLo's Avatar
    HoonLo is offline LX NINJA
    The netherworld
    I could have sworn they were available a while back but freakin crazy expensive....... I have not seen any one use them yet however, and with the money thrown around on this site some body would have them already.
    Much you have to learn....Teach you I will!
    12.93 @ 106 so far....
    You may not be interested in HoonLo but HoonLo is interested in you!
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by HoonLo View Post
    ^^Agreed.
    Flanman's Avatar
    Flanman is offline I'ze done been Stu'd
    Dec 2005
    Northern Illinois
    Jesel has a super expensive setup which requires extensive machining ogf the head for them to fit. It is really a high buck race setup. Harland Sharp is working on a setup also, but from what I know it has a few issues that need to be resolved.
    '05 Magnum R/T-Inertia 407" stroker
    '70 GTX 440-6 (Needs resto)
    '66 Belvedere (Project car)
    '10 Ram 1500 Laramie Crew Cab 4x4
    Quote Originally Posted by Cam View Post
    I just happen think different then most sometimes.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    I have the first set out there. There was a re-design required to make them work properly and I've been waiting on the manufacture to complete the changes. It will not require changes to the retainer/valve or keepers. But it will require some grinding on the heads to clear the rocker and new valve covers.
    OP, the rockers are not the issue. I don't know your build. Hopefully it doesn't require anything more than some new longer push rods. But I've also seen several sets of heads that were built incorrectly, valve stem height issues, wrong retainer and keepers. And of course, the best of the best, those BS Rev valves that cost many a guy a top and bottom end.
    Any pic"s???.
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    Yeah, Jesel has roller rocker's that go for $2,000+. Then you have to machine the block for oil passages to switch to solid lifters, Machine the heads to fit, mount, clear the roller rockers, Have custom push rods made, then you need a expensive set of tall valve cover's, $1,000? So I guess about 5,000$ for adjustable valve train and your good to go!
    dacaman12 is offline LX Padiwan
    Jul 2009
    Oshkosh, WI
    So far, no one has produced a running engine with the Jesel setup. When I say extensive modifications, I mean just that.
    I have a suspicion that Arrington will be the first to get the Jesel deal to work. I have already ground a solid cam for one. It is installed, and the heads are torqued..................
    Jun 2007
    West Milford, NJ
    Any pic"s???.
    Nothing broken, had the top end apart, put it back together and it was quite loud, took it apart again, driver side went completely silent when i retorque'd everything, but the passenger side still is loud. I talked to fargo about it and he said it happens quite often because the rockers are a pain to get torque'd correctly and not make noise.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Are you certain the oil passages are clean. Your discription is very odd. I have to say this, so please excuse me if it sounds like a stupid question. But are you aware our lifters are oiled through the rocker shaft, down the push rod. Did you inspect everything for any type of obstruction??. I ask only because of what you said about the driverside.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Sounds like you either have the wrong pushrods or the MDS lifters are not happy with how aggressive the cam lobes are.
    BFNY PERFORMANCE
    RIP My Friend
    Jun 2007
    West Milford, NJ
    I have non-mds lifters, i had a new cam put in a while back, ran fine with the push rod lengths i had, i had custom length pushrods from 402 made along with my little boy cam, then i went to a more agressive cam, ran completely fine for a while, had the top end apart one time and never sounded correctly after that.
    Hemi31's Avatar
    Did you mix up the pushrods and maybe put the rockershafts on the opposite banks?
    BFNY PERFORMANCE
    RIP My Friend
    Jun 2007
    West Milford, NJ
    no, checked like 20 times i thought the same thing.
    roswald0511's Avatar
    roswald0511 is offline RIP Clifford
    Where the Wire was filmed
    What about the ones HHP was supposed to be offering?
