Results 1 to 5 of 5
    youngceez's Avatar
    youngceez is offline LX Newbie
    replacing t stat without fan mod
    If you replace you t stat without a fan mod will you engine run any cooler? what t stat to use?
    thanks
    2007 sublime Daytona # 1080 removed moldings, 18% window tint, 22" dropstar ds02 6" lip, 265/35/22, straight pipes and resonators
    70GT6's Avatar
    70GT6 is offline LX Padiwan
    Aug 2005
    IL
    Only at hwy speeds. - sitting there or in slow traffic = no change.
    I am running the "Prestone" which is actually the Cooper/Shaw. Get a good one with the air valve - do not mess with the cheapies.
    Look here lots of Info: Alternate thermostats for the LX Hemis
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    yes, you will run cooler, the fan mod is really just to force cool the engine. I am running a robert shaw #383170, it's a 170* thermostat, have had it for a little over a year, no CEL's, It's also a fail safe type, meaning if the thermostat goes bad it will default to open, so that the worst that happens is your car would take a long time to heat up instead of overheat.....I think a lot of guys are running a 180*.....these are pretty much tried and true. I think I have just been lucky with the one I have.
    youngceez's Avatar
    thanks for the info
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    The 4128 Motorad defnitely gets my vote. It's a 180 t-stat and I did get CEL on it's little brother the 170 model....
    The 170 model runs just a degree or two too cool for HAL... not too cool for your car, mind you, but if you start your car and immediately start to cruise you will never get up to the 180 or 181 degrees required to avoid the CEL.
    Edit: I run mine without the fan mod for now because I do tons of highway miles and very little around town. At one point I had the parts for the fan mod but not the time to install.... most of the parts got assimilated into my alarm/remote start installation though. heh.
    Did the radiator cap mod: SRT8 is here....
    The Hemi says, "VROOOM!" Hemi Registry #00420
