Results 1 to 15 of 17
    Radiator confusion
    Im wondering whats the basic difference in an rt and srt raditor.if its a bigger radiator .is upgrading it a big deal?
    bipto's Avatar
    New Hampshire
    Search is your friend...
    The Iron Mistress Galleries
    R.I.P. Dave...
    Daniel454's Avatar
    Daniel454 is offline MAG V
    Nov 2005
    Union Grove, AL
    4 different radiators exist...
    Base
    Towing Package
    SRT
    and Max Duty (overseas export)
    As you go up that list each get deeper... Upgrading up to the SRT model is fairly simple, just need the hoses to go with them. The Max Duty one has special connectors that have to be made, they are not available in a way that will work.
    2005 Dodge Magnum AWD R/T (MINE) - MySpace Profile
    2006 Chrysler 300C SRT8 (Wife's)
    ive searched but so much comes up im more confused then before.i know that the r/t have 1 type radiator and the srt's have which ? is it a straight swap or is there more to it ?
    this is what comes up on parts seachs.
    Home
    Log In
    Your Account
    Catalogs
    Auctions
    Shopping Cart
    Order Status
    Contact Us
    Policies
    Mechanical Catalog Cooling system , Radiator
    2006 Dodge Charger
    Alternator
    Automatic transmission
    Body hardware
    Brakes
    Cooling system
    Cooling fan
    Cooling fan
    Radiator
    Radiator
    Reservoir
    Reservoir cap
    Thermostat
    Thermostat housing
    Water pump
    Water pump
    Electrical
    Emission system
    Engine
    Exhaust system
    Front drive axle
    Front suspension
    Fuel system
    Hvac
    Maintenance & lubrication
    Rear suspension
    Starter
    Steering
    Steering column
    Transfer case
    Universals & rear axle
    Keyword or Part Number
    Description Year MSRP Price Core Price Your Price
    Radiator, charger, magnum, 300, standard and heavy duty 05-07 $321.00 $253.44
    Radiator, charger, magnum, 300, severe duty 05-07 $357.00 $282.48
    Radiator, charger, magnum, 300, severe duty ii 05-07 $472.00 $372.24
    Radiator, charger, magnum, 300, maximum duty 06-07 $478.00 $377.52
    There is a minumum order value of $20 for every order placed. We do not accept American Express cards, so please select a different card.
    Copyright 2007 Intelligentz Automotive Corporation
    Daniel454's Avatar
    Nov 2005
    Union Grove, AL
    When he said search, he meant search HERE on LX Forums...
    Parts numbers:
    5137 691AA Std
    5137 692AA Severe
    5170 742AA Severe Duty II
    5175 367AA
    MAX Duty
    Threads about them:
    And you thought you knew about LX radiators...
    Radiators revisited
    oh sorry .i misunderstood.
    so has anyone determined the difference in the cooling capacities between the 2 radiators the severe duty and severe duty ii ?
    Hal'sMag is offline Wax On - Wax Off
    Feb 2007
    L.A., Ca.
    Matt and i did the Max duty, which have totally different fittings and hoses, but mount right up in the same spot. they move the front condenser and trans. coolers forward about 1".
    R/T hoses would not fit, but we both added the Police oil cooler at that time. I ended up using a Cool flex custom hose for the bottom to the Police oil cooler fitting, and a cut down Chevy hose on the top.
    Not having a SRT (severe duty II)to compare to, I can't say if the hose diameter is the same as the R/T, but the core will be over twice as thick.
    If anyone has a SRT radiator out of the car, and can take some inlet / outlet measurements, I can take them from my stock R/T system I removed and compare.
    PM me.
    Just a grocery getter!
    it would be nice to be able to see what the difference is in the the core thickness.
    2005rtmag is offline 2005rtmag
    Wilmington, N.C.
    I called a dealer parts counter today and he confirmed using my vin# that my RT does indeed have the 5137 691AA standard radiator. He said he could only find listed one more and that must be the SRT radiator, part # 5137 692AA. I gave him the severe duty II part number 5170 742AA and he was able to find it, but said he had no info on what it came in. He had no info on the Max Duty radiator even after I gave him the part #.
    I'm considering pulling my 3,000 lb. boat from NC to Fl, a distance of 590 miles and I am a little worried about overheating. Maybe, I should buy the 5137 692AA Severe cooling radiator and install it first.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by top banana 1966 View Post
    The core difference is 1". The stock RT rad is 7/8" thick and the SRT is 1-7/8". The SRT unit bolts right in no problem, with no other changes, I've done it.
    Daniel454's Avatar
    Nov 2005
    Union Grove, AL
    Quote Originally Posted by 2005rtmag View Post
    Mopar Super Center, or the Mopar Store can get you any of the 4.
    FYI, The Severe Duty I radiator was from the Police model or those that had the towing package.... SO it would be sufficent for towing but I would check prices on them, if you are spending the money, i would suggest going with the SRT radiator (Severe Duty II)...
    cool thansk i have the rad coming in from clevland pick a part.ill have it installed by the week end.
    Pale Rider's Avatar
    Pale Rider is offline Magnum Come Loudly
    Mar 2006
    Western WA
    R/T with SRT Radiator - Hoses?
    For those that upgraded to the SRT Radiator, you used SRT upper and lower hose, correct?
    Reason I'm confused is this...
    Upper hose, charger, magnum, 300, 5.7l, w/o engine oil cooler 06-07 $19.80 $12.87
    Upper hose, charger, magnum, 300, 5.7l, w/engine oil cooler 06-07 $30.85 $20.05
    Upper hose, charger, magnum, 300, 6.1l 05-08 $31.85 $20.70
    Since the 6.1 listing does NOT mention an oil cooler, (because it WILL have one? Not an option?) I'm just wanting to know if there is an issue with the hoses.
    2006 Stone White MRT
    Sidewinder Cam, Mopar Long Tube Headers, Magnaflow Cats, Magnaflow Mufflers
    13.422 @ 102.84
    All that and a CHROME instrument bezel! YES!
