Is it possible to put a stock RT exhaust on one of the V6 models of the Magnum? Thanks.
quick answer: No...v-8 to v-6 for starters
Actually, the correct answer is yes. You could put it on there. Would it be a direct bolt on? Probably not. (why do you think V8 to V6 matters? We're not talking V8 to I6 here) Should you put it on? Probably not, it'll rob torque by reducing back pressure too much. Would it sound good? Doubtful. Would the V6 be better off going to the muffler shop and getting custom exhaust? Yep, it would sound better, perform better, and likely be cheaper.
But, "is it possible"? Yes.
My answer would be sure....for enough money anything is possible!.....but why? Just go to a local shop and have them put something on 4 you. If you want to buy my stock set let me know.
Okay okay, within reason:
Throw all of your money and time at it:
SURE, it'll fit like a glove and work like a charm!
