I got a set of new long tubes and I need to have a bung welded on them for my wideband. Where did everyone put theirs?
"DETONATOR"
most go in the drivers side collector behind the #1 primary.
RIP NHDave
Mine is in the collector but anywhere before the cats...
2013 CHALLENGER SRT8 AUTO IN BLACK
LMI TRUE CAI
MOPAR LOWERING SPRINGS
BLASTIN BOBS AXLE BACK W/ RESONATORS
MAGNAFLOW MID W/ HIGH FLOW CATS
3.73 GETRAG LSD
EDGE 3400 STALL CONVERTER
SPEEDLOGIX REAR SEAT DELETE
......MORE TO COME....
or you can always go with the dual bung setup for both bank readings...![]()
Skip » Demon Performance
Sales@DemonPerformance.com
1-888-312-3666
I wonder if they have Outback Steakhouses in the Outback?
My LTs have a bung in the collector on both sides but not one before the cats. Behind the collector flange - sorry the pic isnt the best shot
Could I put one up on the number one tube a little higher?
The bung has to be in the collecter and not the primary tube, it also has to be at or above 90 deg up or off the ground so moiture doesn't contaminate the sensor.
6.1 swap......
1.599, 7.46 92.18 mph 1/8
4250 lbs
"you're going to come across people in your life
who will say all the right words at all the right
times. But in the end. it's always their actions
you should judge them by. it's actions, not
words, that matter."
Thanx for the input guys!!
