Results 1 to 7 of 7
    LouZ's Avatar
    LouZ is offline LX Guru
    Dec 2004
    NY in the mountains
    Question - A/F Gauges installation
    Do you think they woiuld be annoying on a a-pillar?
    Lou -05 Magnum RT AWD ---> FRI'd 392
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    You get used to it relatively quickly...
    ekaz is offline all gone
    Jun 2006
    CHICAGO
    I agree, I have a triple pod on the A-pillar and it doesnt bother me one bit.
    Unlawful Gathering
    Click for details!
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
    Redfox0099's Avatar
    North Charleston, SC
    Just be sure to put the bung for the sensor before the cat on the pipe..even if you have to burn a hole in your headers like I did...behind the cat gives you false readings.
    LouZ's Avatar
    Dec 2004
    NY in the mountains
    Quote Originally Posted by Redfox0099 View Post
    You saved me another question !!! Thanks....(about which one).
    I'm think i'm going with PLX AFR meter. It replaces the narrowband.
    Redfox0099's Avatar
    go wideband or don't waste your time
    LouZ's Avatar
    Dec 2004
    NY in the mountains
    The PLX unit is both.....part of it hooks to the stock connector, the wideband to the meter
