Results 1 to 4 of 4
    hemi_charger_RT's Avatar
    hemi_charger_RT is offline Its got a hemi
    MD
    pulling fuse 11 clears all codes?
    pulling fuse 17 for about 30 minutes of fun in a empty parking lot later to see how its gonna feel with the noesp and wondering if fuse 11 being pulled will clear all my codes after pulling 17?
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Yes it will.
    BFNY PERFORMANCE
    RIP My Friend
    fnkychkn's Avatar
    greasy cardboard box
    pulling fuse 11 will only clear PCM codes. you'll need to power down the other modules to clear their codes. easiest way is to disconnect the battery.
    MikeEast's Avatar
    Ducktown, Georgia
    AND! if you don't get some mileage on it after dropping power, you'll likely not pass emissions tests. Just had this happen with my seldom used 96 Dodge Ram 2500 Van. "OBDII readiness test" failed - major pita trying to get that cleared up.
    Mike
