Results 1 to 5 of 5
Thread: Pull Fuse 11??
    Magnum375 Jr's Avatar
    Magnum375 Jr is offline First NA 3.5 in the 14's
    Dec 2006
    PA
    Pull Fuse 11??
    My dad got the JET tb spacer and installed it, and it threw a code P0113, so he took it off, and it still throws the code. Does pulling fuse 11 get rid of the code?
    RIP Maggie - (Aug 07, 2007 - Dec 04, 2011)
    charleston, sc
    Pull the Jet spacer.
    Mike Seay
    Member #2258
    2008 GC Overland 3.0 CRD.
    2006 Brilliant Silver MSRT8 (sold)
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Sounds like you forgot to hook up the IAT plug........or you broke the sensor.
    BFNY PERFORMANCE
    RIP My Friend
    fnkychkn's Avatar
    greasy cardboard box
    like Hemi31 said, check your IAT sensor. could have just set if you had the key on with the sensor disconnected. pulling fuse 11 for 15 seconds should clear it if the circuit is OK.
    Dec 2006
    PA
    It cleared it....without the jet spacer in....everything was plugged in....so i think closing the hood must have connected it correctly...thanks for your help guys....we are going to put the spacer back in soon to try round two...but i will be here to assist on the install...hehe.
