Just hoping for some input here as I just got back from the dyno and was hoping for some better results then what I got.
First, I went to the same dyno 2 weeks ago and put down 376/373. My mods are, CAI, no cats, cut-outs, zoomers exhaust, and 180 T-stat.
I just got the B&G flash and went back today. Put down 382/375. So I only gained 6 HP and 2 TQ. Obviously I was hoping for better.
The conditions at the dyno were a bit different. But the #'s are SAE Corrected so that shouldn't make a difference. First trip the intake air temp was 77 degrees w/ a SAE correction factor of 1.02. Second trip the air intake temp was 91 degrees w/ a SAE correction factor of 1.04. So the air temp was higher, but so was the SAE correction faster.
The flash leaned me out a bit too. Approx .2 - .5 across the powerband. At the end of my run on the first trip I ended up a 12.0 A/F. W/ the flash I finished with a A/F of 12.5.
I put 92 in my car. And I mixed in 2 galons 100 octane gas to get a good 94-95 mix.
Thats pretty much all the info. Any thoughts? I'm pretty disapointed, expecially with the cost of the flash. :(
You will be missed... R.I.P. :(
