Results 1 to 15 of 29
    typhoon4x4 is offline Banned
    queens nyc
    Ok Gents Serious Question
    Here Is My Dilemma! Come Early Next Year .im Gonna Do 1 Of The Following 3 .nitrous,s/c Or Turbo.then It Hit Me What If I Forgo All The Above An Do A Stroker Kit? The Problem Is That Im Budgeting My Self For About6-7k For Everything Kit And Install.and If I Do A Stroker.what Would Be The Best Kit And Place For Install?
    PPP-Tech is offline Banned
    Feb 2007
    Muscle Shoals, Al.
    install will be about 12-14 hours. Our 392 stroker shortblock cost $5699 for the Indy 392 and $6599 for the PPP 392. Since you already have milled heads, I would go with the Indy 392 since it is a lower compression 392 and when you put the two together, compression will be a reasonable 10.1-10.3. The Indy 392 uses the callies crank, callies rods, and mahle piston and also comes with ARP main and head studs. Here is a dyno sheet from our last 392.
    He went to the track and was trapping between 114.6-115.8 mph in the 1/4 mile.
    Super T's Avatar
    Aurora, IL
    Seems like the stroker is the best option on that list... ie, the least likely to cause you trouble or heartache down the road. Why add complexity to get the same performance you can out of an engine alone? Plus, that leaves the door open to add one of the other options you listed further down the road after your wallet recovers and you get used to the ludicrous power :-P
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Quote Originally Posted by typhoon4x4 View Post
    I would focus on the bottom end(stroke it) if you are planning on the following(Juice.S/C or T-Bo) upgrades...Especially on stock 5.7 bottom...My $0.02
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryOČ Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    Dookie's Avatar
    Dookie is offline PPP-Tech
    Apr 2006
    Baton Rouge, La. GEAUX TIGERS!
    Same opinion here...let Andy hook you up with the best options out from PPP...the most support, the best people, all tuning options...It a no brainer...You'll thank yourself and PPP when it's done.
    If you want plenty of FULL TIME power, with reliability to boot.
    426 Stroker, Compstar H-beam rotating assembly, 218/232 .562/.567 114 cam, CNC heads, Extrude honed manifold, B&G Stage IV, Dynatech LT headers, JBA catback, KW V2's, Custom True Ram Air CAI, 3600 Stall PI Viper Converter, ATI Super Damper, Hemi Shop CNC heads, Diablo CMR tuned
    queens nyc
    This Is What Im Looking To Do Bring The Car In Hang Out For A Day Or 2 Depending On How Much Time Is Needed .write Out The Check Or Cash For The Amount Needed And Drive Home ? Keeping Within The Budget Of 6-7k .including Parts And Labor.those prices include labor?
    Dookie's Avatar
    Apr 2006
    The budget may getcha, little things like gaskets, fluids, head bolts ect ect...then the labor...it's a little over budget, but close i think...I still think it's the best way though...your very close.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Figure for head gaskets,head bolts,crank bolt,windagetray pan gasket........and if it's a shortblock a new oil pump and timing chain assembly........about $350 worth of extra parts.
    BFNY PERFORMANCE
    RIP My Friend
    queens nyc
    Well I Could Go Little Over .im Just Budgeting My Self There To Prevent Myself From Doing Something Stupid Lol........
    queens nyc
    Well I Wanna Get Everything In That Range Kit Labor Etc In That Range .
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    Always plan on 20% more than initial quotes. Never comes out as cheap or whatever as initially estimated.
    Hemi31's Avatar
    well,you can reuse your heads,and swap out for a bigger cam to meet the cubes.just do a shortblock and you can keep it in your budget pretty easy.
    BFNY PERFORMANCE
    RIP My Friend
    crhemi's Avatar
    crhemi is offline LX Padiwan
    Dec 2005
    Kauai, Hi
    Better plan on bigger brakes to.
    Hemi31's Avatar
    He already has bigger brakes.
    BFNY PERFORMANCE
    RIP My Friend
    hemidup is online now Giddyup!
    Nov 2006
    Minnesota
    Personally, I'd go with the stroker first. You can always boost it later if you wish. Just my .02
    My name is Jerry Williams. The Grandaddy of Gen III Hemi Performance
