Results 1 to 9 of 9
    stationwagon's Avatar
    stationwagon is offline ROCK CHALK
    Aug 2009
    Kansas
    o2 sensor extensions
    First off, I assume they are required for all long tube headers right? Second, if you turn off your rear sensors, and don't have extensions, but the mid pipes have the bungs..what other options are there?
    Last...who sells the cheapest extensions?!
    You can PM me if you don't want to post the link.
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Here is a link to Caspers: http://www.casperselectronics.com/
    All 4 of the sensors have to be plugged into their respective harness connector or you will get a code. I have my downstream drive side o2 sensor tied to the underside of the car and use the bung for my wide band sensor. I do run catless mids so that helps. Due to the year model of your car the upstream sensor connectors are different than the downstream sensor connectors.
    richierevs's Avatar
    richierevs is online now I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    HHP sells the O2 sensor extensions as well.
    Aug 2009
    Kansas
    Thanks!
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    HHP has them. I use the bung for my wideband too.
    Mike
    06 Magnum R/T Midnight Blue
    Aug 2009
    Kansas
    Quote Originally Posted by richierevs View Post
    Ok this mount sound stupid, but where are the o2 extensions on the HHP site. I thought I was looking at them yesterday, but realized they were o2 sensor replacements. I saw o2 sensor spacers also, but no extensions.
    Cruisin1966's Avatar
    Cruisin1966 is offline Anonymous
    Oct 2008
    Okotoks, AB
    http://www.casperselectronics.com/st...x.php?cPath=29
    Just check on the connector shape before ordering. These are on my to-do list as I'm about to pull the trigger on some long tubes
    2012 Stinger Yellow SuperBee - Trinity; 8% Tinted Windows; HID's; 4.3S Stereo; Flowmaster Outlaws (Coming Soon: Painted MSRT rims; BC Coilovers; Sportwing Spoiler; Zeitronix ZT-3
    2007 Sublime Daytona #082/150 (The Wife's) - VFN AAR Hood; Danko Cuda Grill; Sportwing Roofline Spoiler; Painted/Tinted Tails, OBX LT's/Super 44's/4" tips; Martin Bro's Rims
    2005 Cool Vanilla Magnum R/T - sold
    2011 GWE Challenger R/T Classic - traded
    2009 Hemi Orange SRT8 SuperBee #178/425 - traded
    2006 Silver Steel R/T w/ R&T - traded
    Oct 2008
    Okotoks, AB
    So, since I can't get at my car to check the shape of the connectors, does anyone know which shape(s) I should order, and make a suggestion on length too, given these:
    Aug 2009
    Kansas
    I would also like suggestions on length. I was told square connections for mine, but haven't double checked. Popeye's Hemi also thought there was a difference between the front and back sensors.
