Results 1 to 13 of 13
    Mar 2008
    Need Help. People with "Y" fuel rail fittings
    As the title suggests, can anyone who has aftermarket fuel rails and has the rear cross over in a "Y" formation, please post pics and let me know where you got it or how it was assembled? I think I need to go that route very soon, to prevent any future fuel leaks.. :(
    1fastsedan's Avatar
    almost Mexico, CA
    I did a "T", but you might find some of the info useful. Here was my thread when I installed them:
    Billet Tech fuel rails. In and awesome! w/pics
    RobAGD's Avatar
    Reston, Va
    Here is my thread - Fuelish Thinking......
    I also did a T
    Knowing what I do now, I woudl be very very tempted to run a full -6an line from the tank to the rail. That would be able the only thing I would change.
    -Robert
    Mar 2008
    well here is my problem, is that i have an "F", and the only way I could squeeze everything back there, it puts alot of weight on teh back of the fuel rail. Basically the only thing from keeping the front injectors from springing a leak are the 2 tiny little screws that hold down my half covers. I took my cover too today, and the front injectors started leaking and spraying a bit. I put the screws back in and they are ok, but I hate thinking that two little screws are basically keeping my car from burning down. Is there any other way to keep the fuel rails down securely into the manifold??
    Need some good ideas badly.
    1fastsedan's Avatar
    almost Mexico, CA
    I don't know what brand fuel rails you're running or what your whole set-up is, but I would put a front cross-over on to equalize the weight and then use some wide washers on the hold downs.
    Mar 2008
    They are CPR fuel rails from BMC, on a 5.7. I had to modify the manifold to make it fit. The only way I can do a front crossover is to have the hose go over the TB instead of under and that wont work for me because it will rub on the hood I have, and it wont fit underneath the TB :(
    RobAGD's Avatar
    Reston, Va
    Post a few pics dude, we can get you sorted out.
    -R
    Mar 2008
    -R
    ill snap some pics tomorrow. Like i said it is fine with the little screws in that hold my half covers. But if one of those strip, I have a major fuel leak. Makes me paranoid as hell
    InferAl's Avatar
    InferAl is online now "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Here is mine, I wil get a pick of it hooked up tomorrow
    Video
    1FST4DR's Avatar
    Ft Laud.....
    Mar 2008
    Yea I think I need something like those. Maybe a better question is what do you guys use to hold down the fuel rails better than those 2 little screws on each one?
    1FST4DR's Avatar
    Ft Laud.....
    Just the 2 little screws bud..2 per rail..
    Mar 2008
    tight tight. as long as everyone only uses those 2 screws Im good
