Results 1 to 13 of 13
    MagFeet is offline LX Padiwan
    Feb 2008
    Jacksonville, FL
    Need Help! Cherry Bomb Vortex Catback
    Can anyone with this catback exhaust please tell me if the h-pipe whatever it is is supposed to be installed with the flat plate between the pipes up or down (the flat piece closer to body of car or closer to ground)?
    To be more specific, I am having some rattling I think is caused by the mufflers touching the heat shield. I already removed the one around the h-pipe, but there is still a rattle. The mufflers are very tightly packed and not centered. I did not have a instruction guide to go by, so I am wondering if it is poor fitment or I installed incorrectly.
    Any help would be great.
    Timmy C is offline LX Padiwan
    Apr 2008
    Bloomington Illinois
    I think it is down. If you you don't get a definate answer in a couple hours I will be back home and I will check.
    Feb 2008
    Jacksonville, FL
    Thank you. Do your mufflers touch each other in the middle? If you can check to make sure, i would really appreciate it.
    jbcook is online now LX Newbie
    Feb 2011
    NC
    Quote Originally Posted by MagFeet View Post
    My muffler did touch so I had the shop weld a spacer between them. If you haven't already, check for the tailpipe hitting the cradle.
    Feb 2008
    Jacksonville, FL
    I am still looking for an answer about the proper install of the "H" pipe with the welded flat connecting part facing the car or the ground (up or down). Thank you.
    bikemanx2's Avatar
    bikemanx2 is offline LX Padiwan
    May 2009
    SE New Mexico
    I have that catback and it doesn't have an h pipe.
    Sent from my DROIDX using Tapatalk
    05 Magnum R/T: SRT Max Cam...030" Milled Heads...Toona Toon...180 deg thermostat..Cherry Bomb Vortex Catback...SRT8 Headers & Mids...Magnecor Shorty plug wires...Roto Fab CAI...VIS CF SRT Hood...3.91 Getrag w/upgraded clutches...22x10 GFG Trento 5's powdercoated black...Danko predator grill and chin spoiler...MTCM & Tranzformer...Pedders suspension bushings...Hotchkis sway bars...Speedlogix/Razor's Edge End Links
    To Come: BCR Coil Overs, REM Strut braces front & rear, Hellion Twin Turbo Kit.
    Feb 2008
    Jacksonville, FL
    I know its not a real H pipe, thus the "H" in quotes. It serves the same purpose and I am not sure what it would be called. They are the pipes that run from the stock mid pipes to the mufflers. There is a welded plate between the two pipes. I want to know if it should be up or down please.
    Apr 2008
    The pipe with the offset bend goes to the passenger side. My mufflers do not touch. There is probably an 1 1/2" between them.
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    tons of pics here...
    My Cherry Bombs Are On!!!!
    -Ryan
    <<<clicky...
    '93 1500 SB - 240k, '05 Magnum RT - 18k, '80 El Camino - 86k
    Feb 2008
    Jacksonville, FL
    thank you so much. That answered my questions. I worry I may have gotten the wrong mufflers, as I pieced this kit together with the pipes and the mufflers purchased separately. I will have to figure out a way to make it fit better, but mine definitely does not have that kind of clearance between the mufflers. Mine are also a flat black color.
    I purchased 2 88102 mufflers that are 2.5" inlet and outlet.
    Feb 2008
    Jacksonville, FL
    i determined 1 muffler was backwards and the "h" pipe was using the bend in the wrong direction. Although the mufflers are reversible, if you look into them, they are not the exact same both directions of flow. Fitment was better, I just need to adjust the tips to look better.
    Interestingly, the exit side of one muffler does not match up the the resonator delete pipe well. It is loose and I do not think I can squeeze the muffler outlet tube to fit the pipe with the clamp alone. I may have to remove it again and lightly pound it to size.
    Apr 2008
    If you have an exhaust shop close you can see if they would expand that pipe slightly for a better fit.
    Feb 2008
    Jacksonville, FL
    Thanks. It maybe worth it. I am curious what some trips around town might do with the change in pitch and volume level. I think I may have made things quieter, but it is too early to tell.
    It would make sense that it is less loud, as the muffler design dissipates sound better if the internal fin is closer to the inlet tube. You may know what I am talking about if you look at a diagram of the vortex muffler.
