Results 1 to 15 of 22
    RandomAccess's Avatar
    Monroe,NY
    N2O Blow Down tube
    Any one install a Zex blow down tube?
    I can't see how this short tube can be routed outside of the car... so I assume it would have to be extended somehow...
    Pics... anyone?
    I searched and found NOTHING... Should I assume that since it's not a go fast item and a safety item... we all just skip it??? LOL
    12.571 @ 106.71
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    You have to have it to run at the track in a magnum. I didnt because my bottle is in an enclosed trunk. Since you are basically out in the open, they will require it.
    MangoInTX's Avatar
    MangoInTX is offline LX Padiwan
    Dec 2005
    DFW Texas
    The reach of the tube would depend on where the tank is mounted.
    I have the tube but need to swap out the valve on the bottle (wrong fitting from factory for the blowoff tube). Where my bottle is mounted the blowoff tube would reach fine once I poke a hole in the bottom of the trunk.
    1FST4DR's Avatar
    Ft Laud.....
    You can allways use a fitting w/ a peice of steel braid..Just a thought..Mine is also in the trunk..Didnt need one...
    FlyByU's Avatar
    May 2006
    Long Island, NY
    RA and I were thinking some rubber hose would do the trick.
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by FlyByU View Post
    That wouldnt look as pretty....Fyi I think the Hose needs to be securely attached to the bottle, Threaded on one end//
    FlyByU's Avatar
    May 2006
    Long Island, NY
    Were were thinking of attaching the tube at the end of the blow down tube with a hose clamp. You wouldnt see it, the metal tube would be the only thing you could see.
    Monroe,NY
    exactly... I would really like to see some install pics...
    All the mags running spray and no one has a blow down install pic???
    (Me thinks saftey is secondary here... )
    12.571 @ 106.71
    BoiseHemi's Avatar
    BoiseHemi is offline KravMagaSpokane.com
    Spokane, WA
    I have mine in the bottom where the spare tire used to go they never said anything about the blow down tube I guess because it is down there under the cover. If they make me I will just go right out the bottom. Sorry can't help with this one.
    05 R/T: FRANK RACING ECONO HEADS: MILLED, PP FOR N20 & SIDEWINDER CAM w/custom push rods, 2 1/2" custom Borla pro, JBA headers & high flow mids, Modified Volant intake, Diablo w/FRI CMR, BT Catch Can, Zex Kit, NoESp., Functional MOPOWER SHAKER!!!!
    BEFORE FRI'd- 309RWHP/358RWTQ
    AFTER
    FRI'd- 360RWHP/385RWTQ
    AFTER DIABLO, NEW PUSHRODS, NEW TUNE, CRANK PULLY & PORTED TB- ????
    bklynmag is offline Maggie under construction
    Brooklyn, N.Y.
    Like BoiseHemi said. Mine is in the bottom of the trunk. No blow down for me.
    DeamonCharger's Avatar
    DeamonCharger is offline LX Newbie
    Roseville
    You can always attach a hose and clamp it down. I've never had a problem getting through tech with this setup.
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Any pics...Thanks
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryOČ Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    Monroe,NY
    What if we just vent it into the lower level.... If it really is okay to have no blow down in the second level... this is the same right?
    Anyone know? (I suspect it's not okay to have no blow down in the lower level either, just that it is concealed from the tech guys, who don't really poke around our new cars much... they don't even ask to open the hood, so who knows if the setup is okay)
    12.571 @ 106.71
    RobAGD's Avatar
    Reston, Va
    RA dont for get you rgoing to need a FireJacket as well for running juice.
    Its been a long time, but is the connector/hose set up a crush fitting the fits into the blowoff on the tank ? Give me some pics of your parts and i can give you some ideas.
    -R
    Monroe,NY
    This is the tube... I don't have pics of mine but its exactly the same... the end won't reach outside of the car... wondering what folks are using to extend it... (or not)
    http://www.tunerschoice.com/xq/aspx/...tLargeView.htm
    12.571 @ 106.71
