Results 1 to 7 of 7
    Sacmagnum's Avatar
    Sacmagnum is offline Juiced and Loving It
    Mar 2008
    Sacramento
    Mopar TCM Promblem
    I installed my Mopar TCM and the first time I drove it I couldn't get pass 3rd gear and 55 mph. I've done no WOT and was going to do the adaption process. But the first step is to coast from 5th gear down.....can't even get it to shift to 5th gear.....any help would be aprreciated.
    Thanks
    Marcus
    2005 Magnum R/T AWD
    JBA HEADERS|HIGH FLOW CATS|JBA CAT BACK|TAYLOR SHORTIES|180 T/S| AFE STAGE 2 INTAKE|DIABLO| ZEX N20 150 SHOT| Nano System | SVS Tune| RDP Torque Converter | R1 CONCEPT DRILLED ROTORS | STAINLESS STEEL BRAKE LINES | DANKO GRILL AND CHIN SPOILER
    Trojan's Avatar
    Mar 2006
    So Cal
    Ive never had to do the adaption process, Did you clear the tranni adaptives with the handheld prior to installing the MTCM?
    Jim "Meister" Edwards
    RIP "SLICK"
    Fargo59's Avatar
    awd axle ratio is probably throwing the TCM for a loop. it needs the ratio changed.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    You have a AWD, you need to set the gears. The mopar TCM is for the RWD RT. No biggie
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by fargo59 View Post
    Ah shut up ya wanker, I was here second.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Go into the quick adjust menu only and change the gears to 3.07's. And thanks RobAGD for knowing the ratio off the top of his head
    Sacmagnum's Avatar
    Mar 2008
    Sacramento
    You guys rock!!!! Change the gear ratio and it worked.
    THanks
    2005 Magnum R/T AWD
