Results 1 to 15 of 18
    typicalmarine's Avatar
    Jun 2007
    Maryland
    Loss of Power w/Cutouts Open
    Long story short, one of my electric cutouts was either ripped off or wasnt welded on completely. I waited from early June until last Friday to receive the replacement.
    I always felt that my power felt "flat" at best with the cutouts open. Back in May during a dyno run I opened them up just to see what happens and sure enough my hp/tq dropped by about 45 ponies.
    Well with both cutouts on and closed I finally have that "snap" back! Chugging around town for so long with them open I forgot what its like to have that power....
    So for those of you who want to go straight pipes - all I can say is I wouldnt do it. Pick up a set of cutouts and have the best of both worlds.
    Strange thing is my tuner (ForeignMuscle) said he had an SRT8 on the dyno and when it's cutouts were opened it actually gained hp! Who knows but it just goes to show how easily the addition or removal of something can drastically change your power.
    Redfox0099's Avatar
    North Charleston, SC
    They will cost you low in Torque but gain on the top end... at least they did on my N/A 426.
    MAN WGN's Avatar
    MAN WGN is offline Livin in the worlds biggest Dust Bowl!!
    Jul 2008
    Midland, TX
    I can feel the difference from when mine are open and when they are closed. But I love the sound of when they are open
    2005 MAN WAGON
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    I ran back to back on the dyno closed vs open and was unable to detect a difference in the curve.
    And I understand exactly what your saying; my SOTP dyno tells me that I'm giving up low end torque also. Although, I question how much. I think the perceived difference with them open is huge, because there's so much damn noise and grunt associated with the same acceleration when compared to them closed. It just *feels* like you should be hauling ass given the car's attitude. But how much of that is real? I dunno. I'm betting not much (based on my totally informal testing).
    8yourM5's Avatar
    8yourM5 is offline Northern CA
    Sep 2008
    U need a big motor to use cut outs. I only lost 5 up and tq with them open.
    PWR 393, Twin 6262mm Turbos, SHR trans, Fore Fuel system, Wilson Hemi Sheet Metal Manifold
    880 RWHP 775 RWT at 16 psi and 17* of timing
    Tuned by Robert@ Ditos motors
    Walk Softly And Carry Two Big A$$ Turbos!!!
    BrianG's Avatar
    BrianG is offline Kinda getting chilly in Indy!!
    Jul 2008
    Lebanon, Indiana
    I also did a back to back dyno pull and saw very minimal change maybe 2hp gain.
    Mar 2008
    i just got my cutouts put on, and it feels that at WOT at higher highway speeds it seems a tad bit more power, but the butt dyno feels liek it is way flat from a stop or dig. Much more throttle response and quickness with them closed from a stop I think
    Jun 2007
    Maryland
    Oh hell ya the cutouts sound MEAN! I really enjoy them but going a couple months not having the ability to close them was rough. I had strep throat for a month and my 45 minute comute to and from work was horrible....
    dacaman12 is offline LX Padiwan
    Jul 2009
    Oshkosh, WI
    It isn't such much the fact that you have cutouts as WHERE the cutouts are. Whether on purpose, or by accident, your exhaust produces wave pulses that "tune in" at various RPMS. These wave pulses traverse you exhaust multiple times, creating peaks and troughs in your torque/hp curve. Consequently, you can "tune" for a certain RPM using more than one length, although the strength of the reflections decay as you go up in "order"...
    ....The cutouts are changing your "tuned length". In effect, they are making your exhaust shorter. THe shorter exhaust means you can take advantage of fewer "tuning points", but also have fewer "out of tune " points in the RPM band.
    ...If your cutouts are at such a spot that you are "out of tune" at peak hp, then a drop in the raw # only makes sense.
    FWIW, to capture the initial pulse, which is the strongest, you would need an exhaust that is longer than your car, lol. You would also have a more pronounced "dip" before and after the RPM you are "tuning" for.
    HemiRedMagnum's Avatar
    HemiRedMagnum is offline LX Padiwan
    Mar 2008
    Well all that I have heard is that you loose the down low torque but gain about 8-11 hp. There is a member here with QTP cutouts that has a closed to open dyno with about that gain. Here is the link:
    http://lxforums.com/board/showthread.php?t=160776
    07 Magnum R/T AWD
    Mods: Diablo,C&L Intake,180 T-Stat, Dual Magnaflows, Moe's Ported TB, PB Underdrive Pulley, TruFiber SRT Hood, custom gauge cluster, HF cats w/ E-cutous. FRI Sidewinder and JBA Shorties awaiting install!!!
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Good to see some new blood here and it may be fortified with some "Hemi Magic", but time will tell.
    Quote Originally Posted by dacaman12 View Post
    Jul 2009
    Oshkosh, WI
    I punched the #s for a typical 5.7L performance package into Pipemax. How do these figures compare to what everyone is running?
    "Chrysler late model 5.7L engine (calc'd 450 flywheel hp @ 5500 rpm)
    __________________________________________________ __________________________
    --- Single Primary Pipe Specs --- for 353.216 CID from 4000 to 6500 RPM
    Diameter= 1.538 Length= 31.3 to 34.5 also 22.7 to 25.9 inches long
    Note> Maximum Primary's Tuned Length= 50.2 to 53.4 inches long
    --- Header Collector Specs (Conventional Straight Tube) ---
    Diameter= 2.848 Tuned Lengths= 18.1 best and 9.1 or 36.3
    H-Pipe= 18.1 X-Pipe= 72.5 distance behind end of Primary Tube ends
    -- Total Exhaust System Tuned Lengths (Primary ends to TailPipe end) --
    Best HP/TQ Tuned Collector Lengths= 18.1 , 36.3 , 72.5 , 145.0 inches long
    Worst HP/TQ Loss Collector Lengths= 27.2 , 54.4 , 108.8 , 217.5 inches long
    Note=> measured from where the Primary Pipes end inside the Collector to
    the point the tailpipe exits into the atmosphere.
    H-Pipe is located at end of Collector, and X-Pipe is located
    usually half-way between end of Primary Pipes -to- tailpipe end
    Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
    ---- Primary Pipe's Harmonics ----
    1st Harmonic = 127.5 inches long ... typically never used
    2nd Harmonic = 50.2 inches long ... longest recommended
    3rd Harmonic = 31.3 inches long ... highly recommended , best Torque Curve
    4th Harmonic = 22.7 inches long ... shortest recommended
    5th Harmonic = 17.8 inches long ... typically never used
    6th Harmonic = 14.7 inches long ... typically never used
    7th Harmonic = 12.5 inches long ... typically never used
    8th Harmonic = 10.8 inches long ... typically never used
    ---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
    1st Harmonic = 145.0 inches long ... longest with Mufflers and TailPipes
    2nd Harmonic = 72.5 inches long ... longest recommended with Mufflers
    3rd Harmonic = 36.3 inches long ... more bottom-end Torque
    4th Harmonic = 18.1 inches long ... highly recommended , best Torque Curve
    5th Harmonic = 9.1 inches long ... reduced Torque , more top-end HP sometimes
    6th Harmonic = 4.5 inches long ... reduced Torque , not recommended
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    so a reccomend length of a long tube primary would be 31.3"
    and when it says reccomended "collector harmonic" length.. is that distance from the header collector to the tail pipe?
    so if you run a cutout, you would want it 18.1" from the header collector?
    just trying to get a handle on the Jargin used here,,,,
    where does exhaust pipe diameter (excluding header primaries) fall into line?
    will having a 2.5" pipe change the harmonics from a 3" pipe?
    or is it all based on length?
    looks like its time to bust out the tape measure
    lou1355's Avatar
    lou1355 is offline Hoosier Daddy - Finder of Weak Links
    May 2006
    South Florida
    I lost boost and power back to back on the dyno with them open. 2-3 psi and 40 hp, as I recall.
    Jul 2009
    Oshkosh, WI
    Quote Originally Posted by dudeiwin86 View Post
    If I understand correctly, "collector length" is from the end of your primaries to atmosphere. whether it be the end of your tailpipe, or your cut-outs.
    ......primary length includes the length of your port......
    The exhaust waves travel at the speed of sound, which changes with temperature (THAT'S why my exhaust valve is smaller than my intake!!!!!!)
    IMO, a change in pipe dia. will change the velocity more than anything else....but I could see where letting the gas expand into a larger pipe would affect the temperature of the gas, resulting in slightly different "tuned lengths". Of course, you would need to run the rpms higher, or increase displacement, to get the velocity back to where it should be with the larger pipes, which may/may not call for different "tuned lengths".
    Wave tuning is quite a complex subject...(bows to the experts)
    Calvin Elston of Elston exhausts done a test, comparing the latest stepped, tri-y race headers against 8 individual 6" long pipes. The results where posted on speedtalk dot com.
    .............Headers where about 15 hp better, lol. If anything can be learned from that, is you can't loss anymore than 15, unless you are making things worse, right?
    I guess the "accurate" answer lies on thought that more of something helps only if you ain't got enough to start with...............
    It would be interesting to see if the location of the cut-outs fall into one of pipemax's "worse tuned lengths".............
    P.S. Forced induction will definately change things. The exhaust temps, if nothing else will be different. i used 113.5% for volumetric efficiency, which will typically produce EGTs in the 1350° range.
