Page 1 of 11 123 ... LastLast
Results 1 to 15 of 155
    mikespy's Avatar
    mikespy is offline Fastest N/A 5.7L Magnum around!!! SOLD!
    Houston
    If ur modded install a catch can!!!
    Noticed since installing heads/cam... my oil consumption has been around 1/2 quart-1 quart every oil change. Got under my car and noticed it was leaking a tiny bit out the exhaust flange of my LTubes. Figured it was the crappy PCV system like the LS1's were notorious for and sure enough after talking to Steve from Frank Racing.. he helped install a catchcan in my ride. Basically the high suction now after all my mods is too much for the stock crappy system. I have helped on a coulple of heads and cam installs and have noticed that STOCK they had oil in the intake and heads. I have had catchcan in for around 100 or so miles and have caught about a TABLESPOON of oil in it. I used a temporary catch can untill i order an aluminum one sometime this week. I used a Husky air compressor oil seperator and installed it inbetween the PCV outlet and the intake outlet. Works like a charm. Inferal also installed one this week and he's got a pic of the can in a PCV thread. My advice to everyone who has mods and hell even stock rides is to install a catchcan to avoid oil entering intake and exhaust. This will also prevent detonation from occuring from oil being ingested into the intake. My ride has now stopped leaking out the exhaust flange. Guess after 6000 miles on the new heads and cam it had started to collect near the flange.
    Good luck boys!! And keep on modding!!
    2010 SRT8 Challenger...
    MODS: Magnaflow Competition exhaust, Roto-Fab CAI.....
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    So where's the "How to" write up Mike???
    440 Stroker Short Block 4sale!! (tentatively sold)
    2010 MSHS Stroker N/A Champion!
    WickedSRT8's Avatar
    WickedSRT8 is offline Hi-Tech Redneck
    Northern Virginia
    I'm not Mike... but this might help...
    http://www.pbase.com/rsrock/oil_catch_can
    The link to the Husky air pump filter isn't correct... here it is.
    http://www.homedepot.com/webapp/wcs/...&distance_1=50
    07 CSRT8 I, II, III Sunroof
    13.352 @ 106.02 (Stock)
    RWTQ: 411.17 @ 4737 rpm RWHP: 407.09 @ 5958 rpm
    MikeEast's Avatar
    Ducktown, Georgia
    I've never seen any indication of oil at all in my hose from the pcv to the AirHammer. Is that not the norm?
    Mike
    (Mostly stock 5.7L)
    mikespy's Avatar
    Houston
    Quote Originally Posted by MikeEast View Post
    Mike
    (Mostly stock 5.7L)
    The hose that is attactched to where the oil is put in your car and that runs to the CAI is left alone. No catchcan is installed there. This is needed to be left alone so it can suck into the system. The catchcan is installed on the other side/pass. side. Thats where the oil is being sucked in by the intake from the PCV valve. No oil would be really seen in the hose to the CAI.
    BrilliantBlackHemi's Avatar
    Feb 2004
    Been here 7 years!
    Not the hose on the Air Hammer, the one between the PCV and the port on top of the manifold and behind the throttle body. PCV is written on the hose. There is oil in all of them. More on modded cars. That's what is making your throttle plate black on the inside. I've installed a catch can I got from Elite Engineering (eliteengineering.com) like Sgt Stanko did on SRT8oc.com. Works good. Already seeing a small amount of oil in the can after a week.
    R.I.P. Dad aka DynoBob
    mikespy's Avatar
    Houston
    Quote Originally Posted by WickedSRT8 View Post
    Great links Wicked!!!
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Hmmm..... Are these modded cars also seeing oil on the plugs - like Al has seen?
    mikespy's Avatar
    Houston
    Quote Originally Posted by MadCharger View Post
    If they are it's probably the PCV system or the lack of it!!
    InferAl's Avatar
    InferAl is online now "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Just put in yesterday and around 100 miles look at it
    Video
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by BrilliantBlackHemi View Post
    So you installed it a week ago and we haven't seen any pictures?? What's up with that?
    The Iron Mistress Galleries
    R.I.P. Dave...
    Feb 2004
    Been here 7 years!
    I've been working.
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    Not only on modded cars. The 6.1s probably all have this. Some folks are woking on it at the OC.
    http://www.srt8oc.com/forums/showthread.php?t=8891
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    So is this just a Hemi thing or is the 3.5 having the same problem? I read where one guy had to have the TB and intake cleaned.
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    told ya!!!!
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
