Results 1 to 7 of 7
    risky's Avatar
    risky is offline LX Guru
    nj
    I now believe a catch can works but I have a question
    What oil is it catching, where is it originating from? How exactly does it work? Cleaned mine today after 4-6 weeks and there was a decent amount in it.
    Tomahawk cam, corsa, diablo, Bt catch can, Airhammer, 402 rockers , V-3, Eyelids, ID wheels ect. ect. ect.
    slideway's Avatar
    slideway is online now Onward, through the fog
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by risky View Post
    A Catch can stops oil mist from being drawn into your intake manifold(and then into the heads and comb. cham.) from the PCV valve, comming out by the valve cover. Over time you can get a lot of oil in the intake and can cause preignition.(knock)
    Fargo59's Avatar
    yep. ive found i have low knock levels, even at the track, and when inspecting my pcv valve i usually found no oil. 1000km of using my catch can and i have a tablespoon of oil already.
    Ladybreeanna's Avatar
    Ladybreeanna is offline Shut up and go make me a sandwich!
    Jun 2007
    Lake Mary, Florida
    That what I had after 3 months & I dont drive everyday!
    Mopar hood struts, tint, Calipers painted color of Barney, K&N CAI. Demolded. Badazz engine cover
    BT sill plates & emblem, Police pkg flash & Magnaflows hoes! 180 T stat, BT catch can, BT center caps. BT sill plates. Rear air diffuser. Blinged out license plate holder.
    Mar 2008
    ^^^^That's about right.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    Super T's Avatar
    Aurora, IL
    Better answer about where it comes from - The crankcase is full of oil just sloshing around in there while you drive. It splatters off of the moving parts and gets agitated by blow-by gases (no such thing as perfectly sealed piston rings). The blow-by in particular pressurizes the crank case - that's not good, it's not meant to hold pressure and in theory this provides an ever-so-tiny resistance to the pistons during the power stroke. So the PCV is a blow-off valve of sorts to let this pressure out. Well, all those tiny droplets of oil flying around come out w/ the air through the valve. Back in the day, when emissions and pollution were no big thing, they just vented to atmosphere. Now they go to the intake in the name of cleanliness - and the oil goes w/ that air (which is otherwise, in theory, clean).
    This is the oil that the catch can catches.
    HerDaytona's Avatar
    HerDaytona is offline Wifeys Grape Ape
    Dec 2007
    Where it's Warmer
    ^^^ Real nice explanation
