Results 1 to 8 of 8
    robstorredr/t's Avatar
    robstorredr/t is offline LX Padiwan
    Jun 2007
    Scottsburg, IN
    How safe is nitrous on the 5.7 hemi
    Ok guys I know this has been discussed on more than one occasion on these forums but I have to ask, Is nitrous to hard on the pistons on the hemi motor. I have heard the piston crown is very weak and nitrous would be to much for it to handle. I am not looking for more than a 50 to 75 shot. Looking at ZEX smart shot system. I am obviously looking for the safest way to go here so any help would be appreciated.
    Thanks in advance
    Super T's Avatar
    Aurora, IL
    As safe as it is on any other motor (not exactly foolproof). 75 is a fairly mild shot, as long as you have the right safeties in the system you should be fine so long as you don't burn it every time you drive. I'd say you'll knock 15% of the life outta your motor as a guess.
    HoP1 is offline LX Newbie
    Jun 2007
    Huntington Beach, CA
    When injecting nitrous you must remember that a specified amount of fuel must be added at the same time as well. In order to accomplish this you must:
    A) Use a wet system which adds both N2O and fuel at the same time.
    B) Use some style of a rising rate fuel pressure regulator with a port for the N2O to be attached to, to be able to increase the fuel pressure under use.
    C) Have some form of programming available to be able to add fuel at that given load vs rpm.
    Nitrous is nothing more than a means of adding cylinder pressure (which makes the power) by being introduced into the cylinder in a gaseous state. Increasing cylinder pressures you increase the static compression ratio by a percentage which means more horsepower. Nitrous is very safe when used correctly. Get it wrong it becomes catastrophic.
    MikeEast's Avatar
    Ducktown, Georgia
    There are lots of writeups about nitrous, and I've only heard of a few cases where something real bad happened. But with a plastic intake manifold, one sneeze can have your Hemi inhaling shards of plastic debris and that's a bit hard on the inside bits I'd expect.
    I'd love to have 100 more horses for less than 10 bucks each, but for me anyway, the risks outweigh the benefits. I'm saving for an all-motor solution.
    Mike
    bklynmag is offline Maggie under construction
    Brooklyn, N.Y.
    Lots of members are using nitrous on the 5.7 motors. I installed my ZEX kit last fall and only use it on the track. I have been through about 3 full bottles thus far using the 75 shot. Shaved about 7-8 tenths of a second on the 1/4 mile. Take your time on the install (lots of good info on here). If you monitor your sparkplugs and don't go nuts spraying constantly you will be fine.
    5.7 Personal Best: 11.46 w 1.59 60'
    6.1 Personal Best: 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Coming Soon
    Mods: Busted 6.1
    Jun 2007
    Quote Originally Posted by MikeEast View Post
    Mike
    Only way I can see a "plastic" intake exploding would be if your firing on an intake valve i.e. a backfire. Haven't seen a backfire on a DIS system for sometime. Would take a component failure or some wacked timing table to cause that. Not to mention I run superchargers on vehicles with plastic intakes with intake pressures of up to 1bar of boost e.g. 14.7:1 psi of boost. Haven't split yet. Point being plastic intakes are stronger than you give them credit for.
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Quote Originally Posted by bklynmag View Post
    Now that's what I'm talkin' about, John!
    John Y
    Big D's Avatar
    Big D is offline Will Race ... for beer
    Feb 2006
    Stow, Ohio
    Please read this article:
    Nitrous Details
    Some very great information in here.
    •2006 DODGE CHARGER DAYTONA R/T TOP BANANA #516•FRI Street Heads•Milled .030•Ferrea Valves•Ti Retainers•FRI Sidewinder Cam•Mopar Longtubes•Dynatech Power Cats•Zoomers Catback• 6.1L Fuel Rails•6.1L Injectors•CMR Tune by DynoSteve of RDP Motorsports•Mopar CAI•SRT-Style ESP Mod "NoESP"•Billet Technology Catch Can•MotoRad 4128•Innovate Motorsports Wideband/LC-1 Kit
    Dyno'd @ 296.47 RWHP/354.71 RWTQ (Before Cam)
    Mustang Dyno'd @ 377 RWHP/389 RWTQ (After Cam & Heads & CMR Tune by DynoSteve)
    13.295 @ 105.90MPH @ National Trail Raceway, LX & Beyond Nationals, June 15, 9:05A.M.
