Results 1 to 5 of 5
    BoiseHemi's Avatar
    BoiseHemi is offline KravMagaSpokane.com
    Spokane, WA
    High octane with N20
    I know that there are advantages with using higher octane fuel when you use N20 but are there any dissadvantages?
    I am going to use some 104 this weekend at the track to cut down on the chance of detonation....never had any but I did get a backfire last time. Thanks for the input.
    05 R/T: FRANK RACING ECONO HEADS: MILLED, PP FOR N20 & SIDEWINDER CAM w/custom push rods, 2 1/2" custom Borla pro, JBA headers & high flow mids, Modified Volant intake, Diablo w/FRI CMR, BT Catch Can, Zex Kit, NoESp., Functional MOPOWER SHAKER!!!!
    BEFORE FRI'd- 309RWHP/358RWTQ
    AFTER
    FRI'd- 360RWHP/385RWTQ
    AFTER DIABLO, NEW PUSHRODS, NEW TUNE, CRANK PULLY & PORTED TB- ????
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by BoiseHemi View Post
    If you are still running the 100 shot A mix of race fuel and 93 wouldnt hurt..Just helps w/ detonation..It wont hurt anything..Good luck
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    Only thing to worry about is fouling the cats....race fuel isn't as easy on them, but just ran temporarily you should be ok.
    BoiseHemi's Avatar
    Spokane, WA
    Thanks! I will mix it instead of going straight race fuel. Going for the LOW 13's...at my altitude that shoud be in the mid 12's at sea level.
    AFTER
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    This saturday I had a real low tank when I showed up at the track, maybe 2 gallons left of 93 octane. I added 3 gallons of 100 octane at the track and ran on that all day. Car performed flawlessly and would recommend that.
