Results 1 to 5 of 5
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    HHP or B&G TCM w/ Predator?
    Sold my SC tuner and getting the Predator. Would the HHP TCM or B&G TCM work with the Predator until DS releases TCM support?
    http://estore.websitepros.com/802805/Detail.bok?no=1053
    Mike
    06 Magnum R/T Midnight Blue
    mhigham's Avatar
    Feb 2007
    Michigan
    Electrofied is offline Dismayed by your actions and words...
    Everett Washington
    It would depend on which TCM it is... ALL the TCM's sold from whichever vendor are ALL Seimens units from Mopar with the stickers removed. I cannot speak for the GSM TCM which is claimed to be an AMG programmed unit for the E-Class Mercedes which shares the same NAG1 tranny.
    To see if it will work would need to take into consideration
    You car's build Date
    The TCM part number... Look especially at the last two letters... AF, AK, AJ etc...
    Electrofied
    Magnum is Sold... Now for the new Ride!
    mhigham's Avatar
    Feb 2007
    Michigan
    Well, it would work in my car as is, but could it work with the Predator tune? Might have to flash the tune, then install the TCM.
    My thought was, if the Predator doesn't have TCM support initially, then it should be alright even to leave it in there while programming. Only thing is, the TCM needs flashed in by a dealer, I would rather leave the stock PCM programming in, have them flash the TCM, and then install the TCM.
    hmmm.....wheels are turning....
    Mike
    roswald0511's Avatar
    roswald0511 is offline RIP Clifford
    Where the Wire was filmed
    You might want to send this thread over to the DiabloSport vendor section. They might see it there and be able to help you out.
