HELP PLEASE.... ESP Trouble!!!
I have the ESP delete via RT Junkie's mod. I can't get the lights to go back out even with resetting the switch and restarting the car.
I have also did the 11,14,16 fuse reset and it still won't work.
Any help would be greatly appreciated.
Thanks
Couple of thoughts...
Bad switch?
Wheel sensors, I believe these are normally accompanied by ABS and ESP, so possibly not the issue here.
Thanks Mango, I didn't think about that. I can check that with a Voltmeter cant I?
Just to let everyone know. I got it working after switch was verified. I had to reset the codes with the superchip and it started working again.
Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
