I have a mopar remote start on my car and it is wired into cylinder 7. I have been getting cylinder 7 misfire at startup and last week took the remote start wire off and soldered the wires to try and isolate the problem. I found the plug in cylinder 7 cleaner than the rest and thought it was due to less firing than the other cylinders. Then, I have been getting some black stuff in the radiator overflow that is turning the overflow container black, and I am seeing the radiator full of pressure even when cool. It is forcing the coolant out into the overflow. I have had it in at the dealer and they said the black stuff is normal but they didn't know why it was forcing the coolant into the overflow. I also run a fan mod that I keep on most of the time and it keeps my temps below boiling. Well reading up on these symptoms today, I have come to the conclusion I have a head gasket leak.
Coolant reservoir dirty looking
Coolant being forced into the overflow
Spark plug cleaner than others
Misfire in one cylinder at startup
Car heating fast under hard acceleration
Pressure in radiator when cool.
C.
) and shut it off and coasted over to the side. My wife wasn't very happy with my escapade.
