USCG, From what I understand, the milling that some shops are offering will raise compression to around 10.2 to 1 which should be fine with 91-93 octane....especially if you have a larger cam which tends to bleed off a bit of cylinder pressure. Its a cheap/efficient way to gain horsepower. Chrysler/Dodge kept compression at a lower value to allow customers to run 89 octane and for emission purposes. Those that run 93 octane all the time such as you/myself can easily take advantage of the hp/tq increased compression will give you. As long as you are not raising high enough to induce pre-detonation you will not effect the longevity of your motor at all.
Stupid Nasty.... 9.59 @ 148
PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
