Results 1 to 10 of 10
    383HEMI's Avatar
    383HEMI is offline 11's are Imminent
    Sep 2007
    Virginia Beach
    PR&D 383 Dyno #1
    Just got back from the dyno. Here are the results:
    395 RWHP @ 5900 RPM
    435 RWTQ @ 4500 RPM
    If you notice after 5900 rpm I went real rich, down into the 11s and HP started to drop off. Thats due to my tune which is a quick fix. I'm sure if A/F would have stayed consistant above 5900 rpm, HP would have kept going up and broke thru 400.
    It has something funny going on, it actually looses power from 4500 to 5100 RPM. Theres some funny torque managment thing going on there.
    Right now I'm running 2.5" exhaust into a 3" Y which may also be a restriction. Might have to go up to a bigger diameter exhaust.
    The cam in the stroker is a mild for the cubes at 218-222 @ 112 lsa so a bigger cam will also help.
    All in all, I feel that I have a great platform for building some great HP and TQ. With some tweaking here and there, 11s are a great possiblity now.
    PH
    422 RWHP 432 RWTQ 1.61 60' (1/8 7.70 @ 86.5) (1/4 12.25 @ 106.9) VMP Dec 1, 2007
    now SCTTuned by Hemifever
    First Ever N/A 5.7 Hemi Ram in the 12s (April 21, 2007 MIR)
    Wifey's Car: 2008 Road & Track R/T Fully Loaded
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Holy **** Plat, those are unreal numbers. Congradulations to both you and Stu for a completely successfull build. I can't wait to she how she does at the track!.
    Trojan's Avatar
    Mar 2006
    So Cal
    Congrats to PH/Stu! Mighty fine work there buds!!!
    Jim "Meister" Edwards
    RIP "SLICK"
    392Stu's Avatar
    392Stu is offline Supporting Vendor
    Nov 2006
    The torque number throug the truck drivelike tells it all. The truck has about 25% drive line loss. I was curious if the 04 would do the same stuff on the dyno as the 03 does with a built engine and it looks like the answer is yes. So the HP is being reduced significantly by either the reminants of the speed limiter or some type of torque managment. Since the peak HP is 5900 It looks like the cam is working. If you go out and run 12.2 to 11.9 with it then we'll know it's making more like 450HP at the wheels and the dyno dip thing is robbing you. Still in a Car driveline at 17% loss it would be 438HP/ 481 TQ which is pretty strong for a 383. And with only a piggyback to tune I think it works. The dyno won't show the inertial effects of the light assy and crank either.
    I bet you stand a good chance of being the first 11's NA truck if you can hook it up.
    Six Offenderl and builder of the finest Fiat Hemi stroker engines.
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    Holy crap!
    Kinda makes me a little excited to see this...
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    very nice build Stu..... I cant wait to see some 1/4 #'s
    Jason
    383HEMI's Avatar
    Sep 2007
    Virginia Beach
    Thanks Guys.
    Not bad for only having Superchips and a PSC1 tune, eh. I can't wait for us truck guys to have real tuning options.
    Track times soon to follow.
    PH
    Flanman's Avatar
    Flanman is offline I'ze done been Stu'd
    Dec 2005
    Northern Illinois
    Nice work Stu. You're going to have one heck of a monster truck PH.
    '05 Magnum R/T-Inertia 407" stroker
    '70 GTX 440-6 (Needs resto)
    '66 Belvedere (Project car)
    '10 Ram 1500 Laramie Crew Cab 4x4
    Quote Originally Posted by Cam View Post
    I just happen think different then most sometimes.
    392Stu's Avatar
    Nov 2006
    I can't wait to see the track times because the other side of the story is the light weight profiled crank combined with 570 g rods and light piston/pin combo will have inertial performance gains that don't show on a dyno.
    383HEMI's Avatar
    Sep 2007
    Virginia Beach
    Quote Originally Posted by 392Stu View Post
    PH
