Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Like Tree7Likes
Thread: Fuel Smell and fuel gauge reading problem !!
  1. #16
    soul infector is offline LX Padiwan
    Jan 2008
    Thanks guys ... specially Legmaker , tomorrow am going to mechanic to see whats going on with the fuel pump and go back to you as soon
    as i have any solution
  2. #17
    Jan 2008
    Quote Originally Posted by legmaker View Post
    gents - in regards to the fuel gauge, be sure to check a VEEEEEEEERY tiny little magnet that is the pick-up for the signal to the guage. it attaches to the metal float rod and slides along the fuel sender as the float goes up or down. i had an issue with my gauge no working correctly as well after my fore hat install and sure enough this littel bugger had fallen out and was stuck to the metal float rod. when i say this thing is small.....i am not kidding!
    If you can get us a picture for that magnet that would be great !!
  3. #18
    goodeforu's Avatar
    goodeforu is offline Dodge Magnum Club #1167
    Nov 2004
    Lewis McChord, WA
    Torque,
    This is what I used when i replace my pump, didn't want to do the screwdriver and hammer.
    Miller Fuel Pump Lock Ring Wrench PT Durango Liberty 9340 | eBay
    Magnesium Magnum RT AWD
    mods completed
    Hood struts, Glove box light, DRL, debadged, Side moldings removed, Blinker mod, E&G Grill, SXT headlights, Borla exhaust, AVIC-Z120BT & reverse cam, Spoiler paint match, Mopar Performance Strut Tower Brace, Airaid CAI, Billet Tech Eng dressing, 180 T-Stat, Police Oil Cooler, BCR Coilovers, Dabears2k Reverse HIDs, SPC 1.50 bushings, Fuse box cover paint match, Radiator cowl paint match, Radiator reservoir paint match
  4. #19
    Torque's Avatar
    Torque is offline Stroke it! Blow it! Spray it!
    Jan 2010
    Jacksonville, NC
    Quote Originally Posted by goodeforu View Post
    Torque,
    O wow I can't justify spending that much cash on a rarely used tool. Thanks for the link though.
    06 MSRT8: HHP Stage 2 Cam, SP Stage 2 Heads, 2800 Protorque Converter, Stage 2 Indy Ported Intake Manifold, Arrington 90mm Throttle body, Kooks Long Tube Headers, Custom Catback, AFE stage 2 CAI, Mopar TCM, BT Catch Can. SOLD
  5. #20
    legmaker's Avatar
    legmaker is offline LMI Intakes....CF intakes for LX/LC
    orlando, fl
    Torque,
    Yep..... same tool I use...... or I should say borrowed from AMP! lol
    this tool makes life much easier and eliminates the chance of punching a hole in the tank with a big screw driver.
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
  6. #21
    Torque's Avatar
    Jan 2010
    Jacksonville, NC
    I'm too dumb to do things the easy way.
  7. #22
    J-Z's Avatar
    J-Z
    J-Z is offline LX Guru
    May 2009
    HMMM,ME GET THAT STUPID RING OFF!!!
    Torque likes this.
    CURRENT MODS
    100mm tb
    INTAKE MADE BY CRISS
    WHIPPLE 2.9L TWIN SCREW WITH DIRECT PORT N20 ACTION BABY
    393 BUILT BY TROY DING WITH LOVE
    Sent from My HP laptop while taking a crap.
  8. #23
    BBoyPersia's Avatar
    BBoyPersia is online now eThug cause talkin **** IRL is dangerous
    Aug 2009
    Silver Spring, MD
    fuel smell - you have crappy lines
    faulty acting sending unit - either pass side connection is bad/loose or you floater is getting caught onto the crossover. you will need to bend the arm towards the front of the car for clearnace
    Follow my build and racing! www.facebook.com/bboypersiart 9.65 @ 139 - 1.380 60'
    Sponsored By: Drag-On Tuning, HHP Racing
    Quote Originally Posted by Jack SickSRT View Post
    BBOY all I can say is !!
  9. #24
    Locadio is offline LX Padiwan
    Feb 2009
    Mexico
    Quote Originally Posted by BBoyPersia View Post
    So this means to replace the rubber line for what?
    When I did the Arrington fuel hat upgrade & Speedlogix fuel lines, the fuel smells start as the OP pointed. I will be happy to fix this due I am tired to checking for leakings without success. Somebody point the rubber lines are not smell proof.
    I was suffering the same cranking problem for months. A simple tune update fixes it! It seems the extra fuel was the problem for long cranking time. Now, it always starts on 2 or 3 seconds cranking, almost as before the upgrade.
    Thanks.
  10. #25
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    if your setup is actually not leaking, then its just the smell bleeding throught the lines. i think someone sold extensions from the hat to connect to the lines outside the car to help with the smell. what lines do you use?
    and as for the cranking problem, a tune cant fix that. on a return setup when the pumps are off, the fuel drains out and theres no pressure. when you go to crank it, if theres no fuel already there, it wont fire up till its there. when you turn the key and wait 2-3sec, you will hear the pumps start and pressurize the system then cut off. i just turn the key till everything is about to shut off then crank it.
  11. #26
    DarthCharger's Avatar
    DarthCharger is online now Supporting Vendor
    Aug 2007
    Cypress, Texas
    This appears to be a chronic issue with the Fore fuel hat and may be an installation issue these Mopars. I had the very same problem with fuel smell and fuel guage not reading accurately. I had Arrington install the Redhorse Racing fuel lines and return but had the smell issue anyway. Also had the start issue. For the smell I just live with it. For the fuel guage, my issue was as described by Legmaker, the sending unit was replaced. In regard to the start issue, I upgraded the electrical grounds for the battery and tranny and installed a new battery. I also wait a few seconds to crank the motor. Based on what I read, there are commmon issues to all of these builds and the remedies have been addressed by folks that have found solutions that seem to work. Beans to all that responded with advice.
    Sheldon@USWForged.com
    Check Out our Latest Wheel Designs
    Visit Our USW Forged Vendor Section
    713.680.8170 main
    2855 Mangum Road Suite B208
    Houston TX 77092
    Arrington forged 392\ProCharger D1SC (11.20/124mph)
  12. #27
    Feb 2009
    Mexico
    Rubber/stainless lines. I will search who offer the hard lines replace the inside the car rubber lines and see what happen.
    Thanks!
  13. #28
    Jan 2008
    I already have Stainless/rubber lines and still smell fuel inside the car everyday i go work in the morning ! so my solution is to keep sun roof open and one of the rear windows in the garage !
  14. #29
    BMWDON's Avatar
    BMWDON is offline I-495 Hater
    Dec 2004
    Southern MD
    the smell seems to permeate the rubber lines, regardless if you have the ss braid around it like I do. I'm guessing you'ld have to upgrade to the poly fuel lines, or is it some kind of hard silicone. I've looked it up before and now I can't recall the material its made from. I think it was a opaque/whiteish color.
    -Bill
    Challenger Mods: PWR 393, Mean Street heads, Procharger D1 pushing 11+psi, SHR Nag1, DSS 1400 axles and drive shaft, SHR trans but with Paramount Dominator and stage2 valve body to finally be error code/limp mode free. BBS CH-R's and custom splitter with 2011 front spoiler. AAC SMD halos, 3K fog lights, white stripes, cervini wing, hotchkis springs, custom 10" sub w/ kicker amp, sequential tail lights.
    2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
  15. #30
    ponch79's Avatar
    ponch79 is online now LX Padiwan
    Mar 2010
    utah
    Getting ready to tackle this install and sounds to be a beeyotch of fun. Where is a good place to get all the fitting and lines and parts ? I will be running a reg. and double pumps return style setup. Is there a write somewhere ?
    UNDER CONSTRUCTION
