Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Redfox0099's Avatar
    North Charleston, SC
    FINALLY I am fixing my Dual Throttle Bodied Intake...with a cutout????
    Some of you "old timers" on this board will remember the utter failure for street-ability that was the Heat Performance Dual Throttle Bodied Intake:
    Shown here installed with my shaker hood taken off:
    Only 2 were ever fabbed up and were not very good on the streets...idling at a stop light was a pain and the computer could not understand all the extra air and would shut put the car into limp mode after 25 minutes on the highway with was a PITA!!!!
    So I plugged it and only used it at the track, I kept a tube installed and would plug in the tube and filter at the track but all the plugging and unplugging and reaching around that hot motor got tiresome so I just left it plugged.
    Well after talking to some smarter people than I am we as a group figured out that if I could cut off the airflow electronically then it would POSSIBLY be a working part...but how to do it? Tim from Creative Turbos gave me the idea of using an exhaust cutout and so I called Dave at DMH Cutouts and got an order placed for a 3.5" singe exhaust cutout..
    I ordered a 3" mandrel bent pipe I will have cut to match my cheap rear intake tube I had made and then use two 3" - 3.5" header collectors to mate the tube to the exhaust cutout....with it being a 3.5" cutout when open it will allow 3" of airflow:
    Should be installed later today or tomorrow morning, I will post some more pics and let you know how it works out.
    Just wanted to say thanks to 392Stu, Beast2, Hogward, Tim at CIS, and Dave at DMH for the help in getting this together.
    Redfox0099's Avatar
    Just to explain a little better the U Shaped Mandrel bent pipe will be cut at the elbow to make a small J shaped pipe to match the cheap pipe I was using but could not weld to.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Not a bad idea!
    BFNY PERFORMANCE
    RIP My Friend
    Flanman's Avatar
    Flanman is online now I'ze done been Stu'd
    Dec 2005
    Northern Illinois
    Very creative. Good job taking crappy execution of an idea and making it work better. I hope it works out OK.
    '05 Magnum R/T-Inertia 407" stroker
    '70 GTX 440-6 (Needs resto)
    '66 Belvedere (Project car)
    '10 Ram 1500 Laramie Crew Cab 4x4
    Quote Originally Posted by Cam View Post
    I just happen think different then most sometimes.
    Redfox0099's Avatar
    I SHOULD be going to Dallas this weekend for out Dyno Day and will try to dyno with the rear intake closed then open to log the difference...the cool thing is it pulls air from the cowl passenger side where the cabin air fliter was and when the rear TB opens you can hear the air coming into the TB down the tube....sound MEAN!@@!
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    Very interesting Nathan!
    Question: what does everyone think about how well the cutout will seal? Won't even a tiny bit of leakage cause the computer to do strange things? I know you're ready for a tune, but I wonder if even the smallest amount of leakage in part throttle situations might make that job very difficult?
    Just chewing the fat...
    Hemi31's Avatar
    Quote Originally Posted by CoolVanilla View Post
    If it seals tight he'll be ok.Remember there is a second TB blade ahead of it as well.
    BFNY PERFORMANCE
    RIP My Friend
    miplank's Avatar
    miplank is offline LX Newbie
    Colorado
    very interesting...
    Hope it works out for ya!
    Right, gotcha. But (and maybe I missed this) that second blade will be actuating all the time now, right? Or are you going to still leave it unplugged all the time except at the track Nathan?
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Doesn't matter bud, it does not close all the way. And yes CV, the slightest leak will still make Hal crazy. Even as much as profiling the throttle blade just tad will get yu slapped.
    Right, forgot about that.
    Nathan, proceed carefully...
    Redfox0099's Avatar
    Hey...it can't be any worse than it is now right????
    Yeah it can Nate; if I understand your current setup, you've got a plug sealing off all possibility of any air being sucked in thru that 2nd TB. So even if that 2nd TB is leaking (as pointed out by Cam is a definitive 'yes') there was no where for it to get any air thanks to the plug.
    Now, if I understand correctly, the plug is being replaced with a cutout. If that cutout leaks, you've now just given that 2nd TB a source of air... and hence our concern.
    Make sense?
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    Looks like an interesting idea... it should help some,
    And, if its "almost" a seal, as long as that is consistent, HAL will learn it and work it out over time.
    Why not just get the thing CMR tuned with both TB's on there? There has to be some controls for the DBW in the CMR software, eh?
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    Well good luck ... and be careful Nathan.
