Results 1 to 12 of 12
    jackiert's Avatar
    jackiert is offline LX Padiwan
    SoCal
    Question Exhaust Bolt Size? Help, please.
    Does anyone know the bolt size and length for the bolts that mate the header/exhaust manifold to the mids/high-flows?
    I want to replace the bolts with better/stronger bolts and would like to know the size and have replacement bolts in hand before breaking it down.
    I have a 5.7 with Gibson shorts and high-flow cats, if it matters. Don't think it does though.
    '07 Torred SRT
    '06 Inferno Red R/T
    (Sold)
    '96 Ford Contour
    Bone stock and tons of miles, minor dings and scratches
    elcobra44's Avatar
    elcobra44 is offline The times they are a changin...
    Feb 2006
    Batavia, IL
    I wanna say they're 3/8 by 2.5... Just make sure ya get stainless..
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    8mm x 1.25.....I believe it's a 1.5mm pitch.
    BFNY PERFORMANCE
    RIP My Friend
    jackiert's Avatar
    SoCal
    Quote Originally Posted by elcobra44 View Post
    Thanks. Another mentioned he thought he used 3/8 by 3". Is 3" on the long side? Is 2.5" the stock size to your knowledge?
    Is that a header bolt to head size? I'm looking for header to mids...
    elcobra44's Avatar
    Feb 2006
    Batavia, IL
    Quote Originally Posted by jackiert View Post
    Might be three.. I think the 2.5" were a little easier to get in there.
    Fargo59's Avatar
    yeah, the header bolts M8x1.25 thread stock bolts are like 60mm. but you want from the header to the cat, right? my JBA's have 3/8 x 3". get some grade 8 bolts (or go back to metric with M10 and 60mm, but grade 10 at least)
    jackiert's Avatar
    SoCal
    Great. Thanks, all. I'll be leaving for the hardware store in a few minutes and this helped me out a bunch.
    jackiert's Avatar
    SoCal
    Update: I finished replacing the bolts with stainless bolts and the Nord-Lock washers. The 3" were too long. 3/8 by 2.5" were the correct size. Thanks again.
    Hal'sMag is offline Wax On - Wax Off
    Feb 2007
    L.A., Ca.
    Using lock washers on that application reqires nor-locks on both the bolt head and bolt nut end, per nord-lock.
    Just a grocery getter!
    jackiert's Avatar
    SoCal
    Quote Originally Posted by Hal'sMag View Post
    ...and that's how I did it. I'm hoping that I have the same success as Cam did.
    '07 Torred SRT
    '06 Inferno Red R/T
    (Sold)
    '96 Ford Contour
    elcobra44's Avatar
    Feb 2006
    Batavia, IL
    The bolts I installed yesterday in a set of JBA's were 2.5" and I thought about ya... Glad you got it worked out!
    jackiert's Avatar
    SoCal
    Yes, I did. Thanks again. I need to loosen them up a bit and raise the exhaust a little with the old "floor jack with a block of wood" method, then re-tighten. I forgot that step, but immediately was reminded when I let her down from the ramps and she started rattlin' on the cross brace. Oh well.
